can this be fixed?
Old 09-29-2005, 12:38 PM
idriveadelsol7's Avatar
Default can this be fixed?
I’m at work right now… I’ll probably take a picture when I get home and under my vehicle. But here’s a little description of the problem I’m having.
There is a rod looking… I believe to be the steering rack and pinion? Not sure but it has a boot like the axels. The rubber boot is ripped part. Somebody told me it will affect my vehicle steering-wise at high speeds and I am experiencing definitely that. My steering sort of has a mind of it’s own and jumps either left or right when I hit speeds of 65mph+. somebody said I might need a new rack/pinion. Thanks in advance.
Old 09-29-2005, 12:48 PM
Imperious: Mod of Valor
JDM-EJ1's Avatar
Default Re: can this be fixed? (idriveadelsol7)
That boot is your CV boot is torn and you'll need to replace it, the easiet way to do this is to just replace the axel. Replace this ASAP you don't want to drive on a bad CV joint.
Old 09-29-2005, 12:50 PM
Default Re: can this be fixed? (JDM-EJ1)
i just replaced my axels... that boot is not my CV boot. unless i am completely wrong.
Old 09-29-2005, 12:58 PM
jameskersten1's Avatar
you thinking of the boot on the rack? best thing I suggest is replace the rack. We have replaced the seal and boot on a few racks before with not great succes.
Old 09-29-2005, 01:02 PM
IHateJDM's Avatar
its not the axle, its part of the steering rack. I know what you're talking about. Mine is ripped too. Has been for 6 months or so now. I still haven't had any problems from it yet though.
Old 09-29-2005, 01:03 PM
ITR#00-1077's Avatar
Are your boots/ball joints from the tie rod messed up??? Those can be damaged after lowering if using a fork to seperate the tie rod from the suspension.
Old 09-29-2005, 01:37 PM
Default Re: can this be fixed? (ITR#00-1077)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#00-1077 &raquo;</TD></TR><TR><TD CLASS="quote">Are your boots/ball joints from the tie rod messed up??? Those can be damaged after lowering if using a fork to seperate the tie rod from the suspension.</TD></TR></TABLE>
did not quite get that...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">its not the axle, its part of the steering rack. I know what you're talking about. Mine is ripped too. Has been for 6 months or so now. I still haven't had any problems from it yet though.</TD></TR></TABLE>
i bought the thing used... and supposedly it's supposed to carry grease inside but mine are complete dry kinda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 &raquo;</TD></TR><TR><TD CLASS="quote">you thinking of the boot on the rack? best thing I suggest is replace the rack. We have replaced the seal and boot on a few racks before with not great succes.</TD></TR></TABLE>
expensive? i need a parts list... so i know what to buy .
Old 09-29-2005, 02:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">
expensive? i need a parts list... so i know what to buy . </TD></TR></TABLE>
steering rack, some PS fluid should be it that I could think of right now
Old 09-29-2005, 03:01 PM
Default Re: can this be fixed? (jameskersten1)
steering rack, some PS fluid should be it that I could think of right now</TD></TR></TABLE>
what?
Old 09-29-2005, 03:05 PM
what?</TD></TR></TABLE>
your were looking for a parts list.....
1. power steering rack
2. power steering fluid
Old 09-29-2005, 04:03 PM
UberMunkey's Avatar
check inner and outer tie rods, and while your at it your front ball joints and suspension bushings. you hardly ever have to replace the rack unless it is leaking fluid or phsically damaged, though it can go bad.
did this steering issue happen all of a sudden? have you modified anything recently related to the steering that may have caused this(wheels/tires, suspension, i noticed you mentioned you had new axles)? when was the last time you got an alignment? i'd worry about all that stuff before you drop $300+ on a reman rack.
Old 09-29-2005, 04:32 PM
dpkelly's Avatar
Looks like items 14 and 15 above which are on the tie-rod ends.
EdWord
04-25-2010 04:01 AM
hueyduey
05-19-2007 12:30 AM
soon2bdropped
01-12-2007 08:37 PM
ForceXVII
07-07-2006 06:56 AM
Yyz
02-21-2005 11:48 AM
Quick Reply: can this be fixed?
