city lights responsible for turbo blinker problem..
the previous owner of my civic installed city lights, and I am under the impression that one of the wires isn't grounding, hence the fast blinker problem. What are some key things to check?
Re: (ejLday)
the fast blinker occurs when there is a break in the fuse. I think you might have used the turn signal bulb wire instead of the fog wire... or check for short or again a bulb thats burnt out. Rememeber some bulbs use 2 filliments which means even though you have the lights on, the other filiment could be burnt out. just check it out
Re: (keemosaki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keemosaki »</TD></TR><TR><TD CLASS="quote">the fast blinker occurs when there is a break in the fuse. I think you might have used the turn signal bulb wire instead of the fog wire... or check for short or again a bulb thats burnt out. Rememeber some bulbs use 2 filliments which means even though you have the lights on, the other filiment could be burnt out. just check it out</TD></TR></TABLE>
**** people, it blinks fast when one of the turn signals burns out
Re: (pdiggitydogg)
yea everything lights up perfectly, and the corner bulb was replaced. i guess I should just investigate the wiring, because the passenger side is fine..
Re: (CDUFF777)
yes guys everything lights up. I know the problem is the right hand drive turn signal-city light but I just wanted to know if anyone had encountered this, or might have a solution?
