rev problem
Old Apr 12, 2011 | 05:59 AM
Honda-ls-hatch's Avatar
Icon3 rev problem
ok so i just droped my engine in yesterday, started it up and it revs striaght to 6k then back down and up etc.. i checked everything ten times, everytings plugged in. Engine drove fine before. it's a 1998 b18b1 in a 1992 civic hatch. The throttle cable is completly lose and it does the same things. any ideas? Please help
Old Apr 12, 2011 | 08:25 AM
mouab18c1's Avatar
Default Re: rev problem
Any CEL? Any vac leaks?
Old Apr 12, 2011 | 01:15 PM
LovinmyTypeR's Avatar
It's a vac leak. I had just did a H22A swap in a hatch right after we started the motor the RPMs jumped strait to 7k. It turned out that we had forgotten to replace the intake manifold gasket . So quick fix with hondata gasket... spray some carburetor cleaner where your gaskets are and if there is a leak your rpms will jump but have a partner with you when you do this so the car can be turned of before anything is damaged..
Old Apr 14, 2011 | 05:55 AM
okay thanks alot. I heard about spraying that and was going to try it out. I'll let you all know if it worked or not. I really dont wanna have to take the intake manifold back off lol
vtec128
Jul 25, 2008 03:22 AM
hbracer
Jul 23, 2005 07:05 PM
lil_greencivic
13
Jun 6, 2005 04:01 PM
THEO-Vtec
17
Jan 21, 2005 07:55 PM
amit
Nov 26, 2002 08:18 AM
