reset ecu when installing new o2 sensor
Old 09-22-2004, 10:59 AM
LAKER HATER's Avatar
Default reset ecu when installing new o2 sensor
do i need to reset my ecu when i install a new o2 sensor?
Old 10-28-2004, 06:08 AM
nickzed20's Avatar
Default Re: reset ecu when installing new o2 sensor (LAKER HATER)
bump because i searched and need to know too
Old 10-28-2004, 06:21 AM
JimBlake's Avatar
Default Re: reset ecu when installing new o2 sensor (nickzed20)
The answer probably depends on what year car? I think the ECU 'learns' the behavior of the new sensor. By resetting, this happens a little bit faster, maybe a little bit better. You don't absolutely 'need' to reset.
Old 10-28-2004, 06:22 AM
boosted k20's Avatar
well if ur orignal O2 sensor went bad cause n the CEL to come on, then u need to reset the ecu. pull the 7.5 "back up" fuse from the fuse box in the engine bay for about 15 seconds. then install it again.
if the light did not come on then u dont need to reset it
Old 11-04-2004, 11:05 AM
Default Re: reset ecu when installing new o2 sensor (boosted k20)
thanks for the info
Old 11-04-2004, 12:08 PM
btownteg
Guest
Posts: n/a
Or you can just diconect the negative cable from your battery, smoke a cig, and put it back on.
Old 11-04-2004, 01:17 PM
gsrboi80's Avatar
Default Re: reset ecu when installing new o2 sensor (btownteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btownteg &raquo;</TD></TR><TR><TD CLASS="quote">Or you can just diconect the negative cable from your battery, smoke a cig, and put it back on.</TD></TR></TABLE>word
poncec23
06-01-2009 04:11 PM
lilshady6796
34
03-27-2009 07:49 PM
EG-HK
09-08-2007 08:55 PM
Car Tweaker
05-06-2007 12:25 PM
hondaguyexsi
01-10-2005 12:53 PM
Quick Reply: reset ecu when installing new o2 sensor
