replacing bearing in skunk 2 shifter
the bearings in my skunk2 shifter are seized. how do i go about replacing them? does skunk sell them? or is this a standard size? they look the same as the bearings in a roller blade wheel.
here are pics of the bearing
Re: replacing bearing in skunk 2 shifter (integra3586)
honestly i think those are the same sized bearings as skateboard bearings. someone correct me if im wrong but i think they are for sure. if they are than throw in some BONES BRIGADE SWISS BEARINGS I THINK THOSRE ARE LIKE ABEC 8 OR 10 SOMETHING LIKE THAT AND DAMN WILL YOUR SHIFTING BE SUPER FAST
Re: replacing bearing in skunk 2 shifter (manyakiexpi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manyakiexpi »</TD></TR><TR><TD CLASS="quote">honestly i think those are the same sized bearings as skateboard bearings. </TD></TR></TABLE>
lol damn skunk2
lol damn skunk2
Z809 is the size bearing, do a search on google and I am sure you will find a bearing supply house. You might have to figure out the ID incase the make different size ID's with the same OD.
Night Owl
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manyakiexpi »</TD></TR><TR><TD CLASS="quote">honestly i think those are the same sized bearings as skateboard bearings. someone correct me if im wrong but i think they are for sure. if they are than throw in some BONES BRIGADE SWISS BEARINGS I THINK THOSRE ARE LIKE ABEC 8 OR 10 SOMETHING LIKE THAT AND DAMN WILL YOUR SHIFTING BE SUPER FAST </TD></TR></TABLE>
Nope, those bearings are slightly larger than skate bearings. I have tried this.
OP: try to pry off the bearing cover, take out the "ring" that holds in the BBs and clean it out w/ WD40 or Tri-flo, then put it all back together.
Re: replacing bearing in skunk 2 shifter (Leofski)
****!!!!!!!!!! i just bought a set of skate bearings. they look so damn close. i will see if it works tonigth. we'll see. but they said if it didnt work i can return them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leofski »</TD></TR><TR><TD CLASS="quote">Nope, those bearings are slightly larger than skate bearings. I have tried this.
OP: try to pry off the bearing cover, take out the "ring" that holds in the BBs and clean it out w/ WD40 or Tri-flo, then put it all back together.</TD></TR></TABLE>
It is hard to pull a metal shied off the bearing, rubber seals are pretty easy.
You could try to run a little PB or WD40 and see if you can get the bearings to break fee. Even if you do they will allways feel a bit rough. I have rebuilt many bearings and they are never as good as new, expiclly if you have run the dry for a while.
Night Owl
1 Post
Re: replacing bearing in skunk 2 shifter (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
Yep usually it bends them. It's worth a try though, especially since the OP is going to throw the old bearing away anyway.
.</TD></TR></TABLE>
ok well i tried cleaning up the bearings, didnt work to well. so im trying to put the new bearing in and i cant get the outer race off. when i punched the old bearings out it left the outer race on. this is being a pain in the ***. any ideas on how to get it out? ive been using a dremel but its not working.
I would replace the ball bearings and that little thing that holds the ***** basically rebuild the bearing and stick a Phillips head in the middle and pry off the bearing by pushing down on the screwdriver
