removing heat shield
Hey guys! I recently installed a set of suspension techinques sway bars in my 99 gsr. The handling is insane! However, the front sway bar is coming in contact with the heat shield behind the cat and this sometimes makes a rattling sound. Is it bad to remove the heat shield, or is it something I could consider doing? Thanks for your replies.
1 Post
Re: removing heat shield (gsrpilot8000)
The heatshields along the exhaust tunnel can safely be removed - I probably wouldn't remove the heatshields bolted directly to the cat.
REVolution
06-02-2004 10:31 AM
ekimmel
04-16-2002 10:14 AM
