Remote wire for amp/sub
I just picked up a Inifinity bass link thingi.
Im not much of a stereo guy but I can install this with no problem Im sure.
Can I use the remote wire from the back of the car thats connected to the antenna to turn on the amp?
POwer ground are both running from the batter and it would be nice to not have to run another wire from the front of the car to the back.
So maybe the Switched power that makes the antenna go up with make the sub turn on ?
thanks
thanks
yeap it will work if you dont have one of those
stereos that raise the antenna
only when the radio is on
otherwise if you play a CD it will not work
