Amplifer installation
Old Mar 7, 2003 | 08:57 AM
ForceXVII's Avatar
Default Amplifer installation
Can amplifier work w/o remote wire?
Old Mar 7, 2003 | 09:03 AM
1BlackHatch's Avatar
Default Re: Amplifer installation (ForceXVII)
It can if you wire a lead from your +12VDC (amp power wire) to the remote input. But this wouldn't give you a way to turn off the amp and hence drain your battery.
Old Mar 7, 2003 | 09:22 AM
koco's Avatar
The new JL Audio amps for one work with no remote wire. Somehow it senses the signal from the headunit.
Old Mar 7, 2003 | 09:29 AM
ForceXVII's Avatar
Default Re: Amplifer installation (1BlackHatch)
My deck doesn't have remote wire. Should I get a newer deck and which type should I get around 200-250? Thanks
Old Mar 7, 2003 | 12:36 PM
CoolKat's Avatar
panasonic got nice decks for about 200 to 250.
heres one for example. u can find them on like ebay for nice prices.
Old Mar 7, 2003 | 12:59 PM
nsxxtreme's Avatar
Default Re: Amplifer installation (koco)
I'm not sure why all amps don't do this, it is not difficult to do.
Old Mar 7, 2003 | 01:32 PM
koco's Avatar
I used a toggle switch in one of my installs to turn on the bass amp.
Old Mar 10, 2003 | 04:28 AM
Bassicfun's Avatar
Much simplier way guys... if you do not have a remote wire from your head unit, tie into the Accessory wire, it is only powered when the key is in the Acc or On position... hence saving you from draining your battery, having to buy a new head unit, having to buy a new amp, or having to install a toggle switch.. I have done this with factory head units for people quite often.. Very simple to do...
Old Mar 10, 2003 | 08:03 AM
koco's Avatar
Default Re: Amplifer installation (Bassicfun)
Sure, connect it to accessory power. The only drawback is the amp will always come on with the key, not a big deal with newer amps. I used a toggle for my bass amp because if I didn't have the engine running it'd drain the battery in a hurry. It gave me the option of having the bass off.
If your radio has a power antenna wire , you can use that as well.
Old Mar 10, 2003 | 08:37 AM
Bassicfun's Avatar
Well the vast majority of anyone who has subs/amps, almost always has the radio on anytime the car is on.. so it works out
Old Mar 10, 2003 | 11:13 AM
CereaLand's Avatar
Default Re: Amplifer installation (CoolKat)
excellent choice my friend.. i just bought one of these babies .. should be cummin in today!
tdcdodger
Mar 29, 2005 02:04 PM
sooo_slow
Audio / Security / Video
Feb 28, 2005 03:21 PM
ChaosUnbound
Feb 24, 2004 04:20 PM
Understeer
Apr 18, 2003 09:15 PM
turbomonkeyexpress
Jan 2, 2003 01:55 PM
