Redline fluid?
Old Jun 23, 2002 | 05:00 PM
The Rob's Avatar
Default Redline fluid?
My shifting has been gettin kinda jacked up lately and I'm not sure if its my tranny. It never grinds when I go into gear, which tells me my synchros are fine, however the gears dont shift smoothly, as in it is hard to get into first, reverse, etc when the engine is running. However when the engine is off and the car is cold it shifts flawless. I am changing to energy suspension MM inserts cause I think mine are old, and I wanna use redline fluid to try and fix the problem. I have a 93 LS, what redline MTL should I be using? Also if anyone might know another reason this would happen I'd love the input. Thanx.
[Modified by Zero_Effect, 2:01 AM 6/24/2002]
Old Jun 23, 2002 | 05:46 PM
vtecdc2's Avatar
Default Re: Redline fluid? (Zero_Effect)
just try replacing the tranny fluid.. i'd recommend honda MTF.
Old Jun 23, 2002 | 07:45 PM
StyleTEG's Avatar
Default Re: Redline fluid? (HoL Lee SHieT)
Sounds like your clutch is not fully disengaging. Make sure your clutch master & slave cylinders are in good condition. Try bleeding them as well.
Old Jun 23, 2002 | 10:07 PM
PaChiLa Leader's Avatar
Default Re: Redline fluid? (StyleTEG)
how to bleed the clutch master cylinder??
do i need to take it to the shop or i can just do it at home myself?
What do i need to know
Old Jun 24, 2002 | 04:06 AM
The Rob's Avatar
Default Re: Redline fluid? (PaChiLa Leader)
O yeah, and I'm a cable tranny BTW.
Old Jun 24, 2002 | 04:38 AM
StyleTEG's Avatar
In that case, you may need to adjust your clutch. I beleave there is a bolt you can turn in the engine bay which does the adjusting, I really don't know a whole lot about it though.
Old Jun 24, 2002 | 04:45 AM
The Rob's Avatar
I know it shifts perfect when the car isnt running. I was thinkin maybe if the tranny side motor mount is shot the vibration might mess my shifting up. Possible? I am changin to ES mounts and changin tranny fluid this week.
Old Jun 24, 2002 | 08:57 AM
JL 74's Avatar
25 Year Member
Not on my GSR but on my AE86, the above solved some of my shifting issues.
Pinarr
Sep 10, 2012 11:14 AM
gosu08
Aug 30, 2010 02:42 PM
tstchatch
16
May 20, 2010 10:25 AM
BlackLudeSR
Jun 21, 2007 01:50 PM
p0pe
Sep 27, 2002 05:11 PM
