Random Bogging..???
Old Aug 19, 2009 | 07:04 PM
fsg231's Avatar
Icon6 Random Bogging..???
just started 2day...i was crusing this morning at 55mph, and all of a sudden no power...when i mashed the pedal, sounded like the engine wasnt breathing. then all of a sudden about 2 seconds later... power... the 5 seconds later no power... then power..this continued till i got to a light,,, when i started to move off in 1st... bogged at 2grand...i mashed the gas... and bogged harder... then power...i shifted into 2nd ...boged again... ...then power..
finally i was crusing in 5th... then booging...then power...
need i mention this was all the time everything....
Old Aug 20, 2009 | 05:52 AM
fsg231's Avatar
Default Re: Random Bogging..???
bump... any ideas..???
Old Aug 20, 2009 | 05:56 AM
Dogginator's Avatar
Daisy... Daisy...
Clogged fuel filter? Do you have any CELs?
Old Aug 20, 2009 | 08:05 AM
fsg231's Avatar
no Cel's, i had one a couple days ago it was my iac, i replaced it... now its gone.. i have no leaks in that area.
Old Aug 20, 2009 | 10:06 AM
worx's Avatar
fuel filter
Old Aug 20, 2009 | 10:21 AM
fsg231's Avatar
Originally Posted by worx
fuel filter
im leaning towards that ....
Old Aug 20, 2009 | 11:45 AM
pokemekon's Avatar
New User
i had this problem too, i took it into fast action and just replaced my spark plugs since they were burnt and corroded, that for me fixed the same problem you were having! i should look into replacing the fuel filter soon too, just grab a autozone filter, cheap and oe replacement met or exceed oem. :thumbsup: hope this helps in any case.
Old Aug 20, 2009 | 01:22 PM
fsg231's Avatar
yeah pluhs were my first guess, i replaced them last nite when i got home, when i drove to work 2day, same problem.. ijust did my fuel filter, ill post a reply on my ride home
Old Aug 21, 2009 | 07:22 AM
fsg231's Avatar
ok...well no use, still having same problem..
heres what ive done so far..
correct timing,
spark plugs,
fuel filter,
on-top of my luck i got a flat tire last nite on my way home... then this morning to work, i lost my crank bolt ... noticed that when my battery light came on, so i pulled over ans saw i had all my belts looked down and saw the crank pully hanging...well went home and called acura bought a crank bolt (15$) keyway (1$) and a timing belt retainer ( 3.44 ) i get whole sale prices...cause im cool like that...anyways im all fixed but wasnt able to tighten the crank all the way, because the engine began to turn with the bolt. im at wirk now and il bring home the crank tool, so i can finsih the job later this evening.
Old Aug 25, 2009 | 06:05 PM
fsg231's Avatar
figured it out...burnt valves... well i guess ill be doing my rebuild sooner then i expected
dipaolap89
Honda CR-V & Element
Jun 30, 2017 09:58 AM
cdrift
Dec 17, 2008 08:03 PM
spitfiremk2497
Oct 3, 2008 10:56 AM
jawsiiv
Aug 16, 2008 12:26 PM
blulude92
May 4, 2003 04:05 PM
