raising compression
Old Jan 17, 2008 | 11:20 AM
4XmattX2_0X's Avatar
Default raising compression
delete
Modified by 4XmattX2_0X at 12:43 PM 4/5/2008
Old Jan 17, 2008 | 11:24 AM
PrinceAli132's Avatar
Default Re: raising compression (4XmattX2_0X)
VAFC is garbage.
And let your tuner adjust and set your timming.
Ali
Old Jan 17, 2008 | 11:25 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: raising compression (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">VAFC is garbage.
Ali</TD></TR></TABLE>
this man is a prophet
Old Jan 17, 2008 | 11:49 AM
racebum's Avatar
Default Re: raising compression (GRAF-FITI)
What exactly are you wanting to do with a compression increase so small? Seriously .2 point isn't even going to give you a tenth in the quarter? If you turn the duration of the cams up you will drop cranking compression thus allowing compression to go higher. Cruise over to the all motor forum and do some reading. You'll find that you can go higher, like 11:5-1 or more with moderate duration cams. My Vette is at 11:1 and it is dinosaur technology compared to the 4 valve honda heads. It also has no problem with pump gas, the cams and tune will do wonders with compression.
Old Jan 17, 2008 | 11:50 AM
Schister66's Avatar
Man U FTW
Head over the the All Motor Forum and see what they suggest...you'll get a lot more in depth answers there
Old Jan 17, 2008 | 11:55 AM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
get a 1 layer head gasket or the mugen head gaket from inlinefour.com
integra123
May 10, 2006 01:05 PM
silversly
Dec 18, 2004 08:02 AM
RobbieG35
Apr 28, 2004 06:28 PM
Notaverage
Dec 1, 2003 04:53 PM
Modifiedinteg
Oct 29, 2003 06:46 AM
