Quick temperature question
Old Jan 22, 2008 | 04:20 PM
SkaiWu's Avatar
Default Quick temperature question
I went for a smog gsr check today and barly passed... well the car runs fine except for the fact the temp needle is almost right on the C and after about a long time it went up up a little bit like 1/5 way between C and half way
| = needle
M= middle
H = obviously
C.|.........M..........H
Modified by SkaiWu at 5:37 PM 1/22/2008
Old Jan 22, 2008 | 04:25 PM
BacardiBreezer's Avatar
Default Re: Quick temperature question (SkaiWu)
How is the thermostat?
Padawan's Avatar
Darth ModerVader
My first suggestion would be to check/replace the thermostat.
Old Jan 22, 2008 | 04:28 PM
posHonda's Avatar
I have the same problem and Ill be replacing my thermostat ASAP.
Old Jan 22, 2008 | 04:36 PM
SkaiWu's Avatar
Thanks for the replies, I'll check that. What else is bad for running on cold?
Old Jan 22, 2008 | 04:43 PM
posHonda's Avatar
You get horrible gas mileage and you shouldnt beat on the car.
Old Jan 22, 2008 | 07:24 PM
SkaiWu's Avatar
How much and where to get a thermostat? my dad said like20$ gotta fix this fast if this is the case
Old Jan 23, 2008 | 08:15 AM
goota's Avatar
acura dealershp, yeap its like 20 bucks
Old Jan 23, 2008 | 08:33 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (goota)
any local parts store will have it....i would recommend a failsafe for about $12, gaurantee to stay in the open postition in the event of failure...make sure you replace the rubber o-ring thermostat gasket as well
jhammond_82's Avatar
Reject Papi
Default Re: (goota)
autozone, or advanced auto, like 8 bucks.
Old Jan 23, 2008 | 12:39 PM
SkaiWu's Avatar
Thanks all, I bought a Chilton repair manual at Kragen to work on the process soon
Old Jan 23, 2008 | 03:36 PM
SkaiWu's Avatar
I didn't change it yet because i was gonna buy tools but it went up 1/4 to near half way on the meter so I actually have no idea right now. It either takes a long long time to warm up or something.
It also takes a long time for other integs?
Old Jan 23, 2008 | 03:38 PM
mrdeadman's Avatar
They let me pick
Default Re: (SkaiWu)
How cold is it outside?
Old Jan 23, 2008 | 03:46 PM
SkaiWu's Avatar
I dunno like... 40-50 degrees?
Old Jan 23, 2008 | 03:49 PM
mrdeadman's Avatar
They let me pick
Does it ever go above 1/4? Mine gets to halfway when I'm driving for an hour when it's at least 80 degrees outside.
Old Jan 23, 2008 | 04:20 PM
SkaiWu's Avatar
yea it went to 1/4 after a long while of driving around, not sure about going "above" 1/4 but if taking a long time is normal then I guess I may not need to change it =\
GiceMob
Mar 26, 2007 09:06 PM
sno
Dec 28, 2004 01:24 AM
Nocturnal
Feb 22, 2004 08:48 AM
^jefs0ng
Oct 8, 2003 12:15 AM
