Quick question on compression numbers
My compression in my 1999 Acura Integra LS w/ 76,000 miles is 175 across the board is that ok? I heard it supposed to be in the 190 range.. is that OK?
Thanks!
Thanks!
https://honda-tech.com/zerothread?id=1481352
With only 76,000 mi that engine must of had a hard life.
Did you have the throttle fully opened?
As long as the numbers are consistent, you should be fine. The ultimate compression is strongly affected by your gauge.
yea that sounds like your throttle wasnt floored...i did mine like that and got 170...when i floored it i came back and got 185-187
