quick question
Old Mar 16, 2006 | 08:26 PM
veilsides2000's Avatar
Default quick question
Okay how would you adjust your cam gears while you are tuning your car with you valve cover over the gears. What im trying to say is that you know that little piece that goes over the cam gears i guess to keep you fingers safe, how do you adjust your gears without takin gof the valve cover???
Old Mar 16, 2006 | 08:28 PM
mr.beeks's Avatar
Default Re: quick question (veilsides2000)
you are supposed to cut it so you could have acces
Old Mar 17, 2006 | 06:55 AM
civexturbo's Avatar
Either cut it off or trim it so you can get to the cam gear(s)
Old Mar 17, 2006 | 07:37 AM
Rikter's Avatar
I've seen people undu all the bolts holding on the valve cover and they take it off. Adjust gear, and just "hold" the valve cover back in place while the engine is running to check how the adjustment did for their engine.
Kinda sketchy but saves time if you don't want to keep taking it off n on or cut your cover.
-Rik
Old Mar 17, 2006 | 01:20 PM
thanks for the replies guys yeah i was trying to avoid cutting it but i guess thats what will have to be done.
athoughts
Feb 5, 2005 09:06 AM
max8455
Nov 15, 2004 10:15 AM
Weel
Mar 17, 2004 05:01 PM
95IntegraGSRAZ
17
Jan 3, 2003 03:01 PM
Scary1109
Dec 15, 2001 10:00 AM
