Quick Installation Question?
Old Jun 10, 2002 | 11:33 AM
SilverIntegra's Avatar
Default Quick Installation Question?
Has anyone replaced the fuel filter? If you have, at what mileage and also how difficult is it?
Old Jun 10, 2002 | 11:49 AM
EL Vap133's Avatar
Default Re: Quick Installation Question? (SilverIntegra)
At about 30K, it is really easy to replace, good luck.
Old Jun 10, 2002 | 12:11 PM
tuco_ruiz's Avatar
just remember to disconnect the fuel line and let the engine use up all the fuel, other wise you'll have fuel all over
Old Jun 10, 2002 | 12:33 PM
Default Re: Quick Installation Question? (tuco_ruiz)
What do you mean by let the engine use the fuel? Where do you disconnect? Sorry never done it before?
Old Jun 10, 2002 | 03:50 PM
Erik_Pb_Foot's Avatar
New User
LET THE ENGINE COOL
when doing this install, loosen the banjo bolt slowly with a rag around it to catch the spilt fuel. After the pressure is relieved and the fuel is done dripping you are good to go on your install. It's not such a big deal like a lot of people make it out to be. There is no point in pulling fuses and cranking the engine and so forth. Just do like I said. Good luck, it's really easy to do.
-Erik
EDIT: Loosen banjo bolt on TOP of fuel filter and hold rag arouund that bolt as the pressure is relieved and the little bit of gas spews out.
[Modified by Pb_Foot, 7:51 PM 6/10/2002]
Old Jun 10, 2002 | 04:19 PM
GSRaCeRbOI's Avatar
Default Re: Quick Installation Question? (Pb_Foot)
yeah its not that hard to do.. I change mine about every 30K w/ a purolator filter from Pep Boys.. it costs around $20... just make sure have a rag handy so u don't spray fuel all over... and if u have goggles maybe put them on as a precaution so u dont spray urself in the face...
take off the fuel cap
you might want to disconnect the battery in case you drop a tool or make a spark somehow just as a safety/precaution..
then loosen the banjo bolt/fitting SLOWLY.. then let it drip/flow and release the fuel/pressure...after it has trickled out loosen the bottom fuel line fitting nut w/ a open end/box end/combination wrench (what are these things technically called?) and make sure u don't bend or twist the fuel line.. it is a hard/metal line and NOT meant to be flexible or bent..
after its undone.. unbolt the bracket that bolts it onto the chassis/firewall and lift it out.. your new filter should have a little baggie w/ new metal crush washers.. replace your existing ones w/ those.. now bolt everything back up and don't make the same mistake I did..
when I changed my fuel filter the first time.. after i was done.. I cranked over my motor a few times and it would not start.. I was like wtf? then i realized its because the new filter is dry and fuel needs to get into the lines/pressurize and pass through the system and new filter...
after your done.. turn the key switch to the ON position a few times (but not start) and let the fuel pump and fuel system pressurize and then try starting it.. check for leaks..
Old Jun 10, 2002 | 04:58 PM
Sh!+F@ce's Avatar
Default Re: Quick Installation Question? (GSRaCeRbOI)
technically i think there called open end crecent wrenches... ehhh i think
Old Jun 10, 2002 | 05:21 PM
GSRaCeRbOI's Avatar
Default Re: Quick Installation Question? (****F@ce)
I thought crescent wrenches were the ones that look like a 1/2 moon.. like its arched/angled?
lolz anyway its all good.. as long as the guy knows which wrench I was talkin about/which wrench to use..
O===[ <--haha thats kinda what the tool I used/was talkin about looks like.. open end/box end/combination wrench.. whatever its called..
EDIT: ok heres a real pic..
i guess its called a combination wrench since sears calls it combination wrench set
u slip the open end onto the nut while holding the gas line so u dont bend/twist or break it..
[Modified by GSRaCeRbOI, 6:30 PM 6/10/2002]
EK22snatch
Aug 23, 2004 06:31 PM
dohced
Feb 25, 2004 07:43 PM
Nate B
Jun 19, 2002 12:12 PM
OKSolSi
May 7, 2002 10:12 PM
laughinxxx
Nov 14, 2001 10:25 AM
