fuel pressure bleed quick question
Old Feb 25, 2004 | 03:29 PM
dohced's Avatar
Default fuel pressure bleed quick question
I was just wondering if you could tell me how to bleed off the fuel pressure. i am sure it is pretty easy but i just need some pointers. i have allready searched but come up with nothing. thanks
Old Feb 25, 2004 | 03:30 PM
dohced's Avatar
Default Re: fuel pressure bleed quick question (dohced)
sorry was not thinking it is a eam fuel rail on a 98 or so ls. thanks
Old Feb 25, 2004 | 03:52 PM
boostn420's Avatar
Just loosen the banjo bolt at the fuel filter. Cover it with a rag first because once its loose, itll leak fuel out.
Old Feb 25, 2004 | 04:02 PM
dohced's Avatar
Default Re: fuel pressure bleed quick question (boostn420)
ok ill try and get back to you thanks
Old Feb 25, 2004 | 05:23 PM
dohced's Avatar
how close to the fuel pressure regulator is the filter. the thing is my friend has a leaky fuel rail the gas is leaking out of a bolt on the top right top of the fuel rail. i was told to bleed the fuel line and take the bolt out and replace it with teflon tape around it but wont the gas. melt the teflon tape.
Old Feb 25, 2004 | 06:04 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohced &raquo;</TD></TR><TR><TD CLASS="quote">how close to the fuel pressure regulator is the filter. the thing is my friend has a leaky fuel rail the gas is leaking out of a bolt on the top right top of the fuel rail. i was told to bleed the fuel line and take the bolt out and replace it with teflon tape around it but wont the gas. melt the teflon tape. </TD></TR></TABLE>
Don't use any sealer or tape on fuel fittings.
Old Feb 25, 2004 | 07:43 PM
ultimatehonda's Avatar
ok to get rid of the bulit up fuel pressure then u should take the gas cap off to relieve the tank pressure, then disconnect the fuel pump fuse and attemp to crank the car over a few times...it will not start and the fuel pressure will be completely relieved. Once that is done then take the banjo bolt off and replace the seal washer, and if the bolt is bad replace that to and it should be good to go.
CRZ1
May 12, 2009 08:53 AM
ek-g6
Jan 25, 2008 11:31 PM
JDMKid71
22
Mar 11, 2006 08:57 AM
xbn83
Dec 3, 2004 07:12 AM
laughinxxx
Nov 14, 2001 10:25 AM
