A question please help!
Old Oct 6, 2002 | 12:46 PM
dbo's Avatar
dbo
Default A question please help!
damn this....
[Modified by dbo, 4:17 AM 10/8/2002]
Old Oct 6, 2002 | 12:48 PM
94acurals's Avatar
Default Re: A question please help! (dbo)
the b18b (non-vtec) motor has lower compression and is more turbo-friendly
Old Oct 6, 2002 | 12:49 PM
ahead's Avatar
i dont think it has much to do with the vtec, the non-vtec engine has lower compression, little bit bigger displacment and the tranny has longer gears which are better for turbo.
Old Oct 6, 2002 | 12:57 PM
dbo's Avatar
dbo
Default Re: A question please help! (ahead)
oh ic, but if u add vtec would it raise compression or would it still perform just fine
Old Oct 6, 2002 | 01:19 PM
ahead's Avatar
if you add a vtec head it shouldnt raise the compresion and yea it would perform fine. i think it might make more power than a non-vtec turbo
Old Oct 6, 2002 | 02:31 PM
piatl7il77's Avatar
vtec should put out more but you would have to run lower boost so you wouldn't get too much over what you are already running. to get the most out of it you should get lower compresion pistons.
Old Oct 6, 2002 | 03:07 PM
vteg's Avatar
New User
The difference in price between a late model GSR and LS could get you a turbo kit.
Old Oct 6, 2002 | 04:57 PM
20lb.teg's Avatar
Default Re: A question please help! (vteg)
Well, if you decide to put a VTEC head on like they were saying you should see very nice HP gains... Well, the reason is because a VTEC head flows so much better than the LS head. People put a $500 port & polish job on an LS and it flows like a VTEC head straight out of the box, so you can put the $500 port & polish job on the VTEC head and reach flow numbers that can never even be attainable by the LS head... I've been toying with the idea of going back to LS-VTEC this Winter so I can get the 600hp monster I've been looking for... Well that'l take a lot more than a VTEC Head and the p&p job. But yah, I might be looking to sell my whole setup soon. So let me know if anyone has any offers as well...
Later,
Sean C.
Old Oct 7, 2002 | 05:56 PM
dbo's Avatar
dbo
Default Re: A question please help! (20lb.teg)
Later,
Sean C.
What does port and polish actually do? So your head would flow better by doing this?
Old Oct 7, 2002 | 06:32 PM
dbo's Avatar
dbo
ttttt
Old Oct 7, 2002 | 07:17 PM
dbo's Avatar
dbo
Default Re: A question please help! (94acurals)
damn this....
Old Oct 8, 2002 | 05:22 AM
20lb.teg's Avatar
Well, porting is the process where a machinist puts your head on a flow bench (measures how many CFM's can flow through your head) and also sometimes a swirl meter (measures how the air moves out of your combustion chamber and at what speed...) and they remove part of the ports (by grinding away metal from the ports) that make the head flow the air more directly to the combustion chamber, and to get a better air fuel mixture into the combustion chamber. Polishing mainlly is after you port a head, the air can flow quicker and with less resistance if it is flowing through or over a smooth surface so it is polished up (not necessarily to a shine) to make the air again flow better. Hope this answers your question, but if not I'll look for some links for you to read so that the holes I left in my explination can be filled.
Later,
Sean C.
vinceg143
Aug 17, 2008 08:30 AM
Vtecme92
Apr 14, 2006 07:16 AM
moondoggieoo7
Jan 14, 2004 05:00 AM
JReed
Oct 25, 2002 07:16 PM
MXPX
Aug 29, 2001 08:22 AM
