Question about transmission 94 LS
My cv axle was faulty and i think it caused my revs to stay at around 3k and then my passenger cv axle snapped and i think it caused my transmission mount to fail bringing down the tranny. I was wondering what do i have to do/ tools i need to lift up dropped tranny and replace the transmission mount and cv axle.
Re: Question about transmission 94 LS
Well at least 2 jacks, some jack stands. axle socket I think it's a 28mm, a few long crow bars might come in handy, 1/2' socket set with an impact gun if you have it or use an extension bar.
Place the jack under the engine block with a piece of wood between to hold the engine and with another jack use another piece of wood and lift up the trans till its level, replace the axles and mount.
The axle nut is a 32mm or a 1-1/4" socket. Need a couple 17mm sockets for the shock fork bolt and one for the castle nut, some needle nose for the cotton pin. Also need a ball joint separator aswell. If you use the fork style make sure to lube it up so not to tear the ball joint boot.
