Question about CTR cams?
Old May 11, 2003 | 01:53 PM
crooked muffler's Avatar
Default Question about CTR cams?
if u just bolt them in with good vs and ret
will u make any power without tuning?
just a question..
i kno u only make "real" power after tuning
Old May 11, 2003 | 02:35 PM
WiggiE's Avatar
New User
Default Re: Question about CTR cams? (anti-ricecake)
Are you talking about putting them in a B18C1? FYI, 00-01 ITR cams are the same as CTR cams.
Old May 11, 2003 | 04:02 PM
neo1z's Avatar
Default Re: Question about CTR cams? (WiggiE)
Yes. Youll make power. Not as much as with tuning - but you know that.
Furthermore, the "VS" and "ret" dont really give you power per se, they just allow you to rev higher - and unless you have an ecu, you dont really need those.
Old May 11, 2003 | 04:04 PM
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about putting them in a B18C1? FYI, 00-01 ITR cams are the same as CTR cams.</TD></TR></TABLE>
I think the exhaust cams are the same and the CTR intake cam is a little more aggressive.
Old May 11, 2003 | 06:25 PM
Default Re: Question about CTR cams? (neo1z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">Yes. Youll make power. Not as much as with tuning - but you know that.
Furthermore, the "VS" and "ret" dont really give you power per se, they just allow you to rev higher - and unless you have an ecu, you dont really need those.</TD></TR></TABLE>
oh well i do plan pn running a chipped ECU....i'm obviously not getting them tuned right away...this is for a b17
Old May 11, 2003 | 07:19 PM
WiggiE's Avatar
New User
Default Re: Question about CTR cams? (97RedTegGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote">I think the exhaust cams are the same and the CTR intake cam is a little more aggressive.</TD></TR></TABLE>
Correction: CTR Intake and Exhaust Cams are the exact same as 00-01 ITR Intake and Exhaust Cams.
Old May 11, 2003 | 07:39 PM
VTECorona's Avatar
Correction: CTR Intake and Exhaust Cams are the exact same as 00-01 ITR Intake and Exhaust Cams.</TD></TR></TABLE>
JDM Civic Type R 11.5mm 243 @ 1mm 10.5 mm 235 @ 1mm
JDM Integra Type R 11.5 mm 240 @ 1mm 10.5 mm 235 @ 1mm
Old May 11, 2003 | 07:49 PM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote">Type Intake Lift: Intake Duration: Exhaust Lift: Exhaust Duration:
Before you correct someone, make sure you know the facts.
I do know the facts. Maybe you should read before you quote something. The JDM ITR cam specs you pulled are '98 specs. The 00&01 specs have the extra 3 degrees of duration, which make up the CTR cams.
Old May 11, 2003 | 07:51 PM
VTECorona's Avatar
gotcha, little confusion in there..
Old May 11, 2003 | 07:52 PM
WiggiE's Avatar
New User
for being kewl about it
Old May 11, 2003 | 08:54 PM
riceball777's Avatar
i have ctr cams in my b16 with no other mod besides a $20 dollar e bay intake. everything else in my engine is stock. stock piping stock muffler stock header.
after i put them in i can only feel a slight increase in power when i bring it to red line. i also think there is a lost in mid range. to really tell you the truth i dont realy feel mush of a difference. i need other mods to help the cams and i need to raise the vtec.
Old May 12, 2003 | 02:50 AM
Xsi's Avatar
Xsi
Don't count on much of a power increase without tuning, I didn't get any. Book the dyno time now
Old May 12, 2003 | 04:46 PM
VTECorona's Avatar
Default Re: (Xsi)
IMO, when upgrading cams I say don't bother with OEM spec stuff because its 'OEM' and is obviously not going to be much more aggressive than stock b16\b18c cams. I say minimum go with skunk2 I's.
Old May 13, 2003 | 07:29 PM
96dc2's Avatar
Default Re: (97RedTegGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote">IMO, when upgrading cams I say don't bother with OEM spec stuff because its 'OEM' and is obviously not going to be much more aggressive than stock b16\b18c cams. I say minimum go with skunk2 I's.</TD></TR></TABLE>
People are making good power with ITR cams. Some at 200 peak and good powerband. It's not just the cams that are holding some people back. Of course you need plenty of tuning and other work done to the motor to achieve those #'s on ITR cams.
Here is a link to one in particular.
I've never seen anyone try to "extract" power out of GS-R/B16 cams, though. That would be interesting to see. But with those cams it would seem better to "tune" them for the mid-range rather than peak power.
Old May 13, 2003 | 07:33 PM
VTECorona's Avatar
Default Re: (96dc2)
You are right, they can make decent power. It all depends on what you're aiming for I guess. When I personally do cams, I'm going skunk2 stage I minimum
integraboosted
Aug 18, 2006 04:40 PM
b18c-1
Jun 14, 2006 12:55 PM
crxh22project
30
Jul 24, 2005 02:24 PM
kenepo_vtec
Jul 4, 2004 08:57 PM
teg92
Oct 31, 2003 03:22 PM
