Question about converting to OBD-I
Old Apr 28, 2004 | 04:38 PM
StolenTeg's Avatar
Default Question about converting to OBD-I
I have a 98 Ls and have been doing some search about converting to OBD-I(For Hondata).
I would need an Ecu? But which ecu would i need? P72 right? But would an GSR ecu be fine for my LS??
I would need wire harness.
Is there anything else that is needed. it seem like those are the 2 main thing?
Modified by StolenTeg at 1:50 AM 4/29/2004
Old Apr 28, 2004 | 05:18 PM
XSSIVE's Avatar
Default Re: Question about converting to OBD-I (StolenTeg)
you need an OBD1 p75 ecu which is an LS ecu...and the harness as you said.
-Mike
Old Apr 28, 2004 | 05:19 PM
B18 CYA's Avatar
p72 gsr ecu has vtec settings so i dont think it'll work with your ls unless you have a vtec head? just my .02
Old Apr 28, 2004 | 05:21 PM
StolenTeg's Avatar
Default Re: (c2nap)
Hmmm it sound too simple to be true??? so i jsut buy the ecu and harness and then plug and play? or is there more to it then what im assuming?
Old Apr 28, 2004 | 05:22 PM
ragerized's Avatar
Default Re: Question about converting to OBD-I (XSSIVE)
you cant just put an obd1 ecu on a obd2 car. just get the skunk2 conversion harness. and a p75 ls obd1 ecu, and you'll be all set.
Old Apr 28, 2004 | 05:33 PM
982drLS's Avatar
Default Re: Question about converting to OBD-I (ragerized)
u don't need to get a an obd-1 distributor or anything?
Old Apr 28, 2004 | 05:49 PM
XSSIVE's Avatar
Default Re: Question about converting to OBD-I (982drLS)
all you need to do an obd1 conversion on an obd2 car is the obd2 to obd1 conversion harness and the obd1 ecu needed for your car (in your LS case a P75 obd1) nothing else is needed, just plug it in and go. then add hondata or a chip to the obd1 ecu if wanted.
-Mike
Old Apr 28, 2004 | 05:55 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragerized &raquo;</TD></TR><TR><TD CLASS="quote">you cant just put an obd1 ecu on a obd2 car. just get the skunk2 conversion harness.</TD></TR></TABLE>
Or you could get a conversion harness from someone else and save a boatload of money.
for overpriced Skank2 products.
Old Apr 28, 2004 | 06:06 PM
XSSIVE's Avatar
Default Re: Question about converting to OBD-I (Kendall)
Yeah forget the skunk 2 harness...while it works fine...it is too much $$$ as stated above...check the vendors forum and get the JDMSH!T.com harness for $78 shipped from Newman good guy!
here ya go...
https://honda-tech.com/zerothread?id=678895
-Mike
Old Apr 29, 2004 | 04:53 AM
StolenTeg's Avatar
http://cgi.ebay.com/ebaymotors...33596 Saw that ecu on ebay, and was wondering if it would be fine or should i go with oem ecu???
frankiecutz
Engine Management and Tuning
Oct 4, 2010 01:15 PM
big-cat
26
Oct 19, 2006 11:14 AM
HybridKOOP
Jun 19, 2006 12:29 PM
brkdwn5
May 1, 2006 04:41 AM
