Question about checking timing
Old Jan 13, 2003 | 06:24 PM
acatak's Avatar
Default Question about checking timing
Im not to sure about how to use the acutal timing light when I check my timing after installing my cams. When I point the light at the lower crank pulley, what will I see. I want to advance my timing to 18 degrees so what will I be looking for. Thanks
Old Jan 13, 2003 | 07:09 PM
b19coupe's Avatar
Default Re: Question about checking timing (acatak)
White mark by itself = TDC. Red mark flanked on either side by unpainted marks = 16 degrees BTDC. 18 degrees BTDC is mark counterclockwise from red mark.
Old Jan 13, 2003 | 07:22 PM
GSRaCeRbOI's Avatar
check this link out.. it should help:
http://www.c-speedracing.com/howto/timing/timing.php
it has pix which would make it clearer than explaining by just text..
hth
royalfelix
Jan 26, 2009 08:08 PM
GReddy SI
Oct 21, 2004 06:41 AM
jdurston
Jun 9, 2004 05:30 AM
90teg
Aug 26, 2003 01:45 AM
rioninja
Aug 4, 2001 05:48 AM
