Pulling to the left when accelerating after axle install - Please Help
Old Jan 1, 2009 | 07:54 PM
98GreenTegGSR's Avatar
Default Pulling to the left when accelerating after axle install - Please Help
I replaced the driver side axle on my 98 GSR today due to a torn CV boot on my old axle. The install went fine, but when I went out for a test drive I noticed quite a bit of pull to the left when accelerating in any gear. When coasting in gear or neutral there is no pull. I have checked that the new axle is inserted all the way into the intermediate shaft, and the tie rod ball joint looks ok. I have searched and found a couple posts describing exactly the same symptoms but none with any resolutions. Can anyone think of anything else to check before I return this axle and start over again with a different one?
Thank you.
Old Jan 1, 2009 | 10:15 PM
Arsenal's Avatar
Default Re: Pulling to the left when accelerating after axle install - Please Help
What axle did you get? If autozone napa etc then another bad axle. Spend more on a set of raxles etc and you will be fine.
Old Jan 1, 2009 | 10:46 PM
Jimmy's Avatar
Global Moderator
I've had similar situation with axles from advanced auto parts.. If you did use the cheaper parts store axles.. it's possible you received a defective axle.. or it's possibly out of balance.. just my .02
Old Jan 1, 2009 | 11:31 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Could be a bad axle. But did you tighten the axle nut completely after the install?
Old Jan 2, 2009 | 02:43 AM
majinsoftware's Avatar
You most likely need to get a wheel alignment.
Or you damaged the lower control arm bush.
Old Jan 2, 2009 | 06:32 AM
Thanks for the replies. The axle I got was a "new" GSP axle from Advance Auto Parts. Should I return this thing for another GSP or possibly get their re-man axle which is some other off brand?
Old Jan 2, 2009 | 09:11 PM
Arsenal's Avatar
Return it and get a decent one. If you would have searched you would have found numerous topics regarding axles.
Old Jan 3, 2009 | 06:21 AM
Resolved. I ended up returning the "new" GSP axle and getting a Powerline reman axle. After installation the pulling to the left when accelerating is gone. Therefore, I either reassembled something wacky the first time, or the axle was in fact faulty. I hope this helps someone in the future. Thanks to those who helped out.
Pwnmeister
Jun 25, 2013 07:55 AM
jmurphy
17
Apr 5, 2011 01:19 PM
wu tang
14
Dec 17, 2007 09:23 AM
MugenHonda
Dec 30, 2005 10:38 AM
