Pulling the engine
Old Jun 17, 2004 | 03:33 PM
grngsr01's Avatar
Default Pulling the engine
To get the engine out... can you pull just the engine? Or do you need to get the tranny off as well...
Other words... whats the easiest way to get the ******* motor out of a 92 integra!!!
Old Jun 17, 2004 | 04:13 PM
grngsr01's Avatar
Default Re: Pulling the engine (grngsr01)
Come on... I did search.. It seems like you can do it through the top, bottom, with and without... whats the best way.
Old Jun 17, 2004 | 04:32 PM
SkRiBLaH's Avatar
it depends on what tools are avalible to you. i just pulled the bitch out with a hoist.
Old Jun 17, 2004 | 05:31 PM
dot this Promo's Avatar
it would be best to pull out the two (tranny & engine). fewer bolts.
Old Jun 17, 2004 | 05:36 PM
nickgmiller04's Avatar
Default Re: Pulling the engine (jsb18b)
pull them out together. use a hoist. a helms will give you detailed instructions on how to do it.
advice: label every plug and **** when you remove the motor. it will help you when reinstalling it.
be patient and unplug everything
Old Jun 18, 2004 | 12:15 AM
Gerbilo's Avatar
Default Re: Pulling the engine (nickgmiller04)
Never done it on a Honda but helped a friend with his jeep... use strong bolts if you bolt any chain to the block, he sheared one off on his...
we also used a fork lift and the motor/trans wasn't supposed to be lifted, so we just bent the **** outta everything since it's such a POS...
Old Jun 20, 2004 | 10:57 AM
Rod.'s Avatar
i pulled my engine without the tranny
aznguy0087
Jul 5, 2007 11:22 AM
Lost_clearance
May 29, 2006 06:41 PM
mikensu
14
Dec 16, 2004 06:11 PM
Inaniac
28
Oct 20, 2002 11:36 AM
accordfreak
Jun 11, 2002 09:52 AM
