94 LS vtec conversion?
Old Jun 18, 2004 | 08:06 PM
duhunter's Avatar
Default 94 LS vtec conversion?
Hi i recently purchased a '94 integra LS non-vtec. Is there any way that is cost effective to install vtec in my car. Or is a swap up to a gsr b18 a better solution?
Ideas?
thanks
Old Jun 18, 2004 | 08:22 PM
White GSR '01's Avatar
Default Re: 94 LS vtec conversion? (duhunter)
search around the net for a DOHC VTEC head and put it on your block, or just go all out and buy a B18C1 or B18C5
Old Jun 20, 2004 | 10:30 AM
Rod.'s Avatar
Default Re: 94 LS vtec conversion? (White GSR '01)
you can get a dohc vtec head from 400-800 dollars
ecu 90-100
stan has lsvtec lines for 48.50 shipped
dowel pins about 20.00
Old Jun 20, 2004 | 11:16 AM
jamessh1's Avatar
Default Re: 94 LS vtec conversion? (redturbocivic)
if you want a complete head with distributor, im, tb, you're looking closer to $700 USD
ARP head and rod bolts (necessary for revving over 7000 rpms) $140
dohc vtec oil pump, water pump, timing belt $150-$200
new rod and main bearings $120 or so
new pistons to get some decent compression ~ $250 with rings
new gaskets (for im, tb, head gasket, valve cover, oil pan) $100 +
and then the cost of labor to install everything if you can't do it yourself.......
95_red_dc
May 23, 2006 08:08 PM
crxhf19
Apr 15, 2005 10:53 AM
mickeywickit
Jul 24, 2004 01:59 PM
heroinbobaa
Apr 14, 2004 04:03 PM
playAho
Dec 4, 2003 09:08 AM
