obd2 ECU code retrieval?
Old Jan 25, 2006 | 01:38 PM
dohcrxl's Avatar
Default obd2 ECU code retrieval?
There is a way to retrieve obd2 ecu trouble codes by a series of turning the ignition switch on and off. I did it once before on a 99 teg but lost the instructions. I need to retrieve a code on my gf's 98 Accord v6. Does anyone know the sequence?
Old Jan 25, 2006 | 02:02 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: obd2 ECU code retrieval? (dohcrxl)
Assuming the Accord is like an Integra, there should be a blue, two wire connector above the passenger side kick panel. Jumper that with a paper clip and turn the ignition to the run position. Do not start the car. The check engine light will flash the codes.
Old Jan 25, 2006 | 07:14 PM
dohcrxl's Avatar
Default Re: obd2 ECU code retrieval? (Dogginator)
That's how you retrieve obd1 civics. Is it also how you do obd2 Accords?
Like I said, there's a sequence with turning the ignition switch on and off. I'm sure someone here knows it but my luck they aren't reading this.
Old Jan 26, 2006 | 02:23 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
I believe you need a code reader to get OBD2 codes. If you go to Autozone, they will read them for free.
Old Jan 26, 2006 | 04:03 AM
JimBlake's Avatar
Look in the Accord forum. Jumper 2 of the pins in the OBD-2 connector to do the flashing-CEL stuff. I don't remember which pins but there's a good thread with a picture...
Old Jan 26, 2006 | 01:03 PM
dohcrxl's Avatar
Default Re: obd2 ECU code retrieval? (JDM_Ej)
No you don't. You can access them either by jumpering pins on the obd2 connector or by a series of cycling the key on and off a number of times and waiting a number of seconds between cycles then watching the cel.
I'd prefer not to jumper anything to avoid accidental frying of the ecu. And I dislike autozone so I'll only go there as a last resort.
Old Jan 28, 2006 | 11:06 AM
dohcrxl's Avatar
Thanks JimBlake.
I have another question for whoever can answer it: According to this diagram https://honda-tech.com/zerothread?id=1502084
I'm supposed to jumper pins 8 and 13. What I need to know is how you identify the pin positions. Do you look at it from the front side and count left to right starting at the top row? Or do you look at the backside of the plug like you would when identifying ecu pin locations?
EL TYPE R
Nov 13, 2011 12:00 AM
95LSv
Honda Civic (2001 - 2005)
Feb 19, 2011 04:55 PM
civicminded3111
15
Jan 23, 2009 06:06 PM
Superorb
Feb 4, 2006 03:28 PM
AzNpRiD3
May 14, 2004 06:05 PM
