Pulling code 17 and 43
Old May 10, 2006 | 08:27 PM
JFG Kevin's Avatar
Default Pulling code 17 and 43
How can i fix those two codes? 17 is something with the VSS (vehicle speed sensor)...do i just replace it? my speed works and everything so i dont know why it would pull that code. 43 is somethin about fuel supple unit or something...any ideas?
Old May 10, 2006 | 08:34 PM
b00sted_hatch's Avatar
Little Hercules
Default Re: Pulling code 17 and 43 (aznstyler119)
just replace the speed sensor. and code 43 if im not wrong you are running to rich or to lean. damn your car is f***ed up lol
Old May 10, 2006 | 09:27 PM
Slo Integ's Avatar
Default Re: Pulling code 17 and 43 (b00sted_hatch)
I know for a fact Code 43 is fuel delivery or 02 sensor.
Unplug your 02 sensor and see if the car runs better.
Also, look into getting a fuel injector cleaner to clean out all ur injectors.
Old May 10, 2006 | 09:30 PM
EF_9's Avatar
Default Re: Pulling code 17 and 43 (Slo Integ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo Integ &raquo;</TD></TR><TR><TD CLASS="quote">I know for a fact Code 43 is fuel delivery or 02 sensor.
Also, look into getting a fuel injector cleaner to clean out all ur injectors.</TD></TR></TABLE>
i swapped my ef with an LS motor and 43 popped on so i changed my o2 sensor and it went away
Old May 11, 2006 | 08:56 AM
Downz's Avatar
Default Re: Pulling code 17 and 43 (EF_9)
does your car backfire or stutter wen you begin to drive? an would it stop you at a sertain RPM between 2.5-4K
Old May 11, 2006 | 11:12 PM
JFG Kevin's Avatar
Default Re: Pulling code 17 and 43 (downs1824)
hum...i have injector cleaners...but i haven't use it in a while...good idea...and i just recently notice that my car been backfiring every so offen..actually VERY LITTLE..but when it does..it's one BIG one...haha..yah..my car is pretty fucked up...i dunno what's goin on...i was thinking about change wire and spark plugs again...oil and ****..see how that goes....so for code 13 just change speed sensor? Its a ITR tranny in a gsr ecu...which sensor do i get..gsr or itr? or are they the same.they look the same...just checkin...i kinda build the motor by my own hands and the trusty old helms....GSR motor with CTR piston and s2 stg 2 cams...tune by hondata...but it RUNS LIKE ****...
Old May 11, 2006 | 11:50 PM
project 2two9's Avatar
get a new speedo sensor and clean your fuel system
Old May 12, 2006 | 04:04 PM
JFG Kevin's Avatar
Default Re: Pulling code 17 and 43 (project 2two9)
which speed do i get? ITR or GSR...it's a itr tranny.. with gsr ecu and dash
Old May 18, 2006 | 03:58 PM
OUT OF ORDER ROB's Avatar
aint all of them the same.
dejay2014
Aug 24, 2014 09:16 PM
phelps38
Jul 16, 2007 06:48 AM
trigga
Mar 9, 2005 01:22 PM
alberto.garrido
Jul 27, 2004 09:33 AM
BoostedGSRBubble
Apr 3, 2003 06:50 PM
