hole in header,CEL
Old Feb 21, 2005 | 01:13 PM
trigga's Avatar
Default hole in header,CEL
i found a hold in my DC header, could this throw a code 43?
Old Feb 21, 2005 | 01:46 PM
primeredbeast's Avatar
Default Re: hole in header,CEL (trigga)
i don' tthink so code 43 is a fuel code it will give ya an exhaust leak which still needs to be fixed though
Old Feb 21, 2005 | 03:41 PM
NJIN BUILDR's Avatar
A hole in the exhaust can show up lean on the o2 if its before the sensor.Fix the leak,clear the code and give it a try.
Glenn
Old Feb 21, 2005 | 03:53 PM
drdisco69's Avatar
Default Re: hole in header,CEL (primeredbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredbeast &raquo;</TD></TR><TR><TD CLASS="quote">code 43 is a fuel code</TD></TR></TABLE>
As far as I'm concerned, THERE IS NO SUCH THING AS A FUEL CODE. There is a code that indicates a problem with the fuel supply system, like one of the sensors the computer depends on to provide the right amount of fuel. Like an oxygen sensor...
Fix the hole in the header, your code will be taken care of.
Old Feb 22, 2005 | 05:00 AM
JimBlake's Avatar
Yeah, the O2 sensor really measures the DIFFERENCE between inside & outside. So if there's exhaust blowing over the outside of the sensor, that throws off the readings, & the ECU doesn't 'understand' why all it's different measurements don't add up.
Old Feb 22, 2005 | 10:03 AM
trigga's Avatar
Default Re: hole in header,CEL (JimBlake)
ok patched what i could see,with thermosteel, i guess ill take the header off this weekend and go all around the weld, the CEL is random some times it will come on some times not, but usally it will but at random time during driveing, if this dont fix the code what would the next cause be?
Old Feb 22, 2005 | 01:29 PM
drdisco69's Avatar
As if my car was reading this and wanted to reinforce what I said....
My car started surging and hesitating today coming back from work. It started losing power, and that Hyundai in the mirror was coming up fast. I was thinking "oh ****, the rings are in the oil pan" as I watch the air/fuel ratio go nuts. I started to hear a hissing noise when I got closer to home. I park it and pop the hood and see a HUGE leak in the exhaust, where the manifold meets the downpipe.
Moral: Giant leaks in the exhaust before the O2 sensor cause it to read incorrectly and throw off air/fuel mixtures. Also my car is a money pit.
Old Feb 22, 2005 | 02:00 PM
JimBlake's Avatar
Default Re: hole in header,CEL (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">As if my car was reading this and wanted to reinforce what I said....</TD></TR></TABLE>AAARrrrgghh. So there's a Honda continuum too? I thought that was just Saabs. There's always gotta be some constant number of Saab problems in the world. When you fix something, there's another Saab somewhere that has to break.
Old Feb 22, 2005 | 02:22 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">When you fix something, there's another Saab somewhere that has to break.</TD></TR></TABLE>
LOL, I've heard that about french cars too. I just stay out of european cars all together, they have that "if it's not leaking, it's empty" thing going on, among other problems.
Old Feb 23, 2005 | 09:55 AM
trigga's Avatar
its not a giant leak, its cracked around the weld, but its is before the O2
Old Mar 9, 2005 | 01:22 PM
trigga's Avatar
i fixed the hold, but still the CEL comes back, any ideas?
SlowB20z
Engine Management and Tuning
Dec 28, 2012 09:12 AM
hondaboy9506
Sep 24, 2010 10:20 AM
phelps38
Jul 16, 2007 06:48 AM
ImThatGuy
Jul 8, 2005 08:02 AM
PhilStubbs
Jan 22, 2005 11:20 AM
