HELP with this damn code 41-defective fuel system.
Old Mar 28, 2003 | 08:13 AM
BoostedGSRBubble's Avatar
Default HELP with this damn code 43-defective fuel system.
I fixed my 41 (o2 sensor by cleaning it). I still have my code 43. Ive 2x checked everything. What exactly does this code mean? Are there specific parts it relates to. Im getting ready to redo my entire fuel rail/injectors. I drove for 2 weeks w/o any codes. One week after tuning i get this crap. Sometimes it comes on, sometimes it dosent. It always goes away when i shut off the car and restart it. It will stay gone till the car gets cold again. As long as i keep driving, it stays gone. HELP PLEASE!
[Modified by BoostedGSRBubble, 1:27 PM 3/28/2003]
Old Mar 28, 2003 | 09:23 AM
TurbodCX's Avatar
Default Re: HELP with this damn code 41-defective fuel system. (BoostedGSRBubble)
Haahahahaha you need to buy a new 02 sensor, that code is a 02 heater circuit code.
brian
Old Mar 28, 2003 | 09:28 AM
Default Re: HELP with this damn code 41-defective fuel system. (TurbodCX)
Fock, i posted wrong. I fixed the 41. I cant get rid of my 43.
Could my o2 not be clean enough and still be causing my code 43-defective fuel system.
[Modified by BoostedGSRBubble, 1:35 PM 3/28/2003]
Old Mar 28, 2003 | 09:41 AM
ATYPR's Avatar
I know this is stupid but, if you just a motor in the car check your injector grounds. Same thing happen to me.
Old Apr 2, 2003 | 07:42 PM
Bontke's Avatar
Default Re: HELP with this damn code 41-defective fuel system. (FUCATYPR)
One problem with checking injector grounds....the computer grounds them! The injectors are supplied with 12v on one side, while the other side (ground) is used by the ECU to fire the injector. I am having the stupid 43 code after and engine swap (B18B to B20Z). I have tried the ground thing and it only made code 16 go away.
Old Apr 3, 2003 | 09:16 AM
R-Toyz.com's Avatar
How did you fix code 41? I'm getting that code right now.
Old Apr 3, 2003 | 06:50 PM
Bontke's Avatar
Default Re: HELP with this damn code 41-defective fuel system. (rtzcom)
He said code 41 was fixed by cleaning the O2 sensor. I fixed my codes. Since I swaped in a B20Z, I had the IAC and ACT sensor connectors swapped. I swapped them back and presto! car runs lean again! NOw all I need is to get it tuned for the 2.0L
91ef_ls
Nov 15, 2006 06:15 AM
JDMhondalude22
Nov 8, 2006 04:55 AM
Rhythmsnewsn
Sep 4, 2006 03:30 PM
PhilStubbs
Jan 22, 2005 11:20 AM
vtecludeh22
Dec 3, 2004 12:03 PM
