Problems w/ conversion harness...
Old Apr 12, 2003 | 02:55 PM
SiR-DC2's Avatar
Default Problems w/ conversion harness...
Has ne1 used an OBD2b to OBD1 harness in an 01 GSR? Did you have any problems? The problem I'm expeirencing is my car will pretty much start once, appear to richen up and die, then it will not start again...now I'm not stupid, I chip computers so I tried everything. I even tried a total of 3 different ecus that are good, my ecu is good and I think my conversion harness is bad. Please anyone w/ input help. I just don't want to go throught the hassle of sending it back to the seller when I MAY just beable to switch a few wires to get it correct. It isn't trowing a code if that help...please help me!!!
Old Apr 12, 2003 | 04:47 PM
WiggiE's Avatar
New User
Default Re: Problems w/ conversion harness... (SiR-DC2)
Try putting a volt meter on the harness. Plug one side into one end and the other into the othe end. That way you can check for continuity(sp?).
Old Apr 13, 2003 | 08:45 PM
SiR-DC2's Avatar
ne1 else?
Old Apr 13, 2003 | 08:50 PM
WiggiE's Avatar
New User
Have you tried what I said yet?
Old Apr 13, 2003 | 09:33 PM
superi0ro1's Avatar
you have to tap the wires for the fuel pump on the jumper. im not sure which one it is on the jumper
Old Apr 13, 2003 | 10:02 PM
SiR-DC2's Avatar
What your saying makes sense about the fuel pump, please post more info for me and roughly what I need to do, WiggiE, I'm not trying to be rude but where the hell would I start??? There are like 70+ wires I have a good OBD1 ecu, and an ecu jumper harness that isn't allowing my car to run, the fuel pump idea sounds like it would solve my problem...it this due to the immobilizer and if so I thouhgt the imm. was built into the OBD2b ecu, please help soon, thanks,alex
Old Apr 13, 2003 | 10:04 PM
WiggiE's Avatar
New User
Default Re: (SiR-DC2)
Honestly, at this point I would just send it back.
Old Apr 13, 2003 | 11:06 PM
threatcon13's Avatar
New User
who'd you get the harness from? I got a harness recently and I had the same problem with my swap..well actually the car wouldn't start (no fuel). So we found out that there was no continuity through the iacv wire on the harness
CRXLST
Jul 24, 2013 11:51 PM
99JdmDc2
Aug 16, 2007 07:43 AM
hmtcrxsir
Mar 25, 2006 08:05 PM
antiJDM
Oct 11, 2004 01:28 PM
