Problems Into Third Gear
Old Dec 17, 2002 | 06:43 PM
mr_mbuna's Avatar
Default Problems Into Third Gear
1995 LS with ACT HDSS Clutch and Clutchmasters Flywheel and New Honda MTF Fluid
I have a persistent problem that has happened before and after my aftermarket clutch and flywheel. Now and then, not all the time or even frequently, my tranny will grind going into third gear. Not as I let off the clutch- its with the clutch pushed in, almost like I'm trying to get into the gear w/o using the clutch.
What's my problem?
Ben
Old Dec 17, 2002 | 06:52 PM
Jmm0056's Avatar
Default Re: Problems Into Third Gear (mr_mbuna)
probably bad synchros, very common in honda trannies
Old Dec 17, 2002 | 06:57 PM
mr_mbuna's Avatar
Default Re: Problems Into Third Gear (Jmm0056)
Bad synchros even though it grinds while the clutch is depressed? I thought synchros were what brought the engine rev's to the proper speed as you release the clutch?
If it is synchros, what am I looking at in terms of parts costs for DIY and then parts and labor for shop?
Ben
Old Dec 17, 2002 | 07:10 PM
SupaTegRS's Avatar
time for a gsr or type r tranny
Old Dec 17, 2002 | 07:29 PM
Acuracy's Avatar
New User
Default Re: Problems Into Third Gear (SupaTegRS)
i have the same problem with my GSR tranny....it would grind goin into 3rd only at high rpms and now i changed the clutch and put on a clutchnet 6 puck and a fidanza fylwheel and now i get the grinding into 3rd during most normal driving....and sometimes 2nd at high rpms, sometimes.
im guessing my syncros are gone as well, but how come the change after i changed my clutch and flywheel?..thanks
Travis
Old Dec 18, 2002 | 08:54 PM
Acuracy's Avatar
New User
Default Re: Problems Into Third Gear (Acuracy)
anyone?
ttt
Old Dec 18, 2002 | 09:05 PM
Brasspremier's Avatar
maybe... you didnt push clutch in all the way..... i dont know
Old Dec 18, 2002 | 10:05 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
synchros
Old Dec 19, 2002 | 04:00 AM
Fuuma0083's Avatar
Default Re: Problems Into Third Gear (CiRcUiTsi)
if your saying that your clutch is depressed.... and it grinds it might be the problem with your Master Cylinder, because it sound more like the clutch isn't disengaged fully.
or just a bad syncro
[Modified by Fuuma0083, 8:01 AM 12/19/2002]
Old Dec 19, 2002 | 06:25 AM
Desslok's Avatar
Default Re: Problems Into Third Gear (Fuuma0083)
3rd gear synchro is usually first to go. You can double clutch it into 3rd and see if that helps.
Old Dec 19, 2002 | 11:04 AM
jonsteR's Avatar
I just recently started griding into 3rd after a track day. Low or high RPM, it would grind going into 3rd. I have a Type-R flywheel, CM stage 3 and a 205K mile 92 LS tranny. I just recently put in some GM synchromesh MTF and the grinding is gone. I have yet to test it on a track again but the grinding i used to get on the streets are pretty much gone. I figured, if my synchros are bad anyway, might as well try it. I suggest you try GM synchromesh MTF. HTH.
Old Dec 19, 2002 | 11:48 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
for jesus christ's sake.. use the SEARCH function!! this must have been covered 6000000000000000000000000000000000 times.. and its not really a problem.. anyone with a 5-speed will encounter it.. the tranny still works.. and it wont really hurt anything.
Old Dec 19, 2002 | 11:54 AM
EJ8 Kenobi's Avatar
Default Re: Problems Into Third Gear (Hatchy-Ownzjo0)
i've seen "Use the search" post more times than posts have been re-topiced...
hatchy jo0 a n00be
[Modified by FrankGSR, 3:55 PM 12/19/2002]
Old Dec 19, 2002 | 12:23 PM
^R@m!r0_(M)
Guest
Posts: n/a
Default Re: Problems Into Third Gear (FrankGSR)
same problem with a friends Si just bad synchro i would say.
Old Dec 19, 2002 | 01:02 PM
dallasyoung's Avatar
Default Re: Problems Into Third Gear (Sears_Teg)
FrankGSR, is that ur car in ur avatar? I wanna see somemore pics!
But yea its ur syncros. Time for a new tranny!
Old Dec 19, 2002 | 01:18 PM
TEGME's Avatar
I would agree with this, I would say it is either your slave or master, try filling your slave cylinder with DOT 3 fluid from the slave (there is a nipple on it) till it comes out the reservoir (displacing any air) and try it. This is what I did and it hasn't ground since.
Old Dec 21, 2002 | 07:01 AM
EJ8 Kenobi's Avatar
Default Re: Problems Into Third Gear (Jiz101)
dallasyoung: https://honda-tech.com/zerothread?id=277074
iheartmygsr
Transmission & Drivetrain
Sep 29, 2008 03:53 PM
wickedEFguy
Mar 27, 2005 12:20 PM
KrispyKreme
22
Jan 10, 2005 11:57 PM
RJL
Nov 28, 2003 11:25 AM
tegmaniac
Jul 23, 2003 08:13 PM
