PROBLEMS WITH DETONATION
Old Sep 2, 2006 | 12:19 AM
cleanda6's Avatar
Default PROBLEMS WITH DETONATION
okay so i got a b20b into my 1990 ls it has a skunk 2 intake and b16 trans
my question is what can i do to stop my car from detonating so much i tried everything .... im going to check my dizzy and spark plugs tommorow but what can it be i have no cels ?? it has no tunning since its not heavily modified or anything close to it
Old Sep 3, 2006 | 11:04 PM
cleanda6's Avatar
Default Re: PROBLEMS WITH DETONATION (cleanda6)
Any one? Do I really need tunning ? Everything seems to be in place working fine just problems when I decelerate or ilde it detonates or seems to sound like it misses what do u guys think ? Any advice would help thanks
Old Sep 3, 2006 | 11:40 PM
qfast817's Avatar
i would get tuning, on my b20v-tec i cracked a sleve with out tuining
Old Sep 4, 2006 | 06:54 AM
Nors's Avatar
Try a higher octane gas. Not the proper solution by any means though.
Old Sep 4, 2006 | 07:21 AM
mmuller's Avatar
Mad Scientist
Default Re: (Nors)
sounds like something else to me.
no detonation when decelerating, ecu cuts gas supply.
whats your base timing set at?
Old Sep 5, 2006 | 11:24 AM
cleanda6's Avatar
the ecu is stock so i would say stock base timing
and it does detonate when decelerating and at idle
Old Sep 5, 2006 | 11:45 AM
mmuller's Avatar
Mad Scientist
Default Re: (cleanda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanda6 &raquo;</TD></TR><TR><TD CLASS="quote">the ecu is stock so i would say stock base timing
and it does detonate when decelerating and at idle </TD></TR></TABLE>
no stock base timing meaning the distributor
when you let off the gas the ecu cuts fuel
No fuel = no detonation
something else is wrong of something is happening when deaccelerating.
Old Sep 5, 2006 | 02:25 PM
cleanda6's Avatar
maybe do i need new dizzy cap or rotor maybe plugs ??? or should i check for proper tdc?? i have an autozone dizzy
Old Sep 6, 2006 | 10:45 AM
cleanda6's Avatar
any 1
Old Sep 6, 2006 | 03:26 PM
mmuller's Avatar
Mad Scientist
check your ignition timing
Old Sep 7, 2006 | 10:52 AM
cleanda6's Avatar
i will thanks
Old Sep 12, 2006 | 11:36 AM
cleanda6's Avatar
cap and rotor are slightly corroted is that my problem?
skiracer8148
Jan 5, 2007 12:33 PM
SC94DB8
Feb 25, 2004 01:27 PM
Tr0LL
Jun 11, 2003 01:17 PM
Honda4CX-T
Apr 14, 2003 06:48 AM
not so civic
Jul 24, 2002 10:05 AM
