hood problems
Old Aug 22, 2003 | 10:04 AM
LsNrG's Avatar
Default hood problems
i know that this is in the wrong area, but my CL is messed up and i dont know howto get the hood up without using the pull on the inside. can anyone help.
Old Aug 22, 2003 | 04:31 PM
VTECorona's Avatar
Default Re: hood problems (LsNrG)
Explain more please, your problem doesn't make much sense. The only way you are supposed to be able to open your hood is to 'use the pull on the inside."
Old Aug 22, 2003 | 04:34 PM
philafelman's Avatar
Default Re: hood problems (VTECorona)
did the plastic hood latch break?? you can usually use some pliers to pull the cable if that is the case....if you can get the car in the air, you can probably do it from underneath the car behind the bumper.
Old Aug 22, 2003 | 05:31 PM
Hites
Guest
Posts: n/a
crowbars are useful . SMASH ****! DIE HOOD!
julianbc2
May 22, 2010 01:16 PM
AznJdmKid
Jul 23, 2009 12:29 PM
alupso
Mar 7, 2006 09:21 AM
rustboy
Feb 16, 2004 06:26 PM
