Problem with obd1 conversion
Old Mar 12, 2004 | 02:58 PM
00b18b's Avatar
Default Problem with obd1 conversion
i drive a 00 teg ls and just converted it to obd1. when i first start up the car it had a lumpy idle which eventually came to a steady idle(600ish rpm). i took the car out for a spin on the hwy and noticed when traveling around 5500 rpm's the needle will start to bounce from 5000-5750ish rpm's and when flooring it past 5500 rpm's the needle just slams down to 0 rpm's. ive tried two 0bd1 ecu's and they both do the same thing. whats wrong with this picture anybody else have this problem?
Old Mar 12, 2004 | 10:40 PM
00b18b's Avatar
bump
Old Mar 13, 2004 | 12:01 AM
DC2*Integra's Avatar
Default Re: (00b18b)
do u have a aftermarket chip?
Old Mar 13, 2004 | 06:01 AM
00b18b's Avatar
Default Re: (DC2*Integra)
nope
Old Mar 13, 2004 | 11:22 PM
Joseph Davis's Avatar
Bad grounds. Check you thermostat housing ground, as well and engine ground, and also inspect your adapter harness carefully.
Old Mar 22, 2004 | 05:02 PM
00b18b's Avatar
Default Re: (J. Davis)
bump
Old Apr 12, 2004 | 04:27 PM
Blown90hatcH's Avatar
Does it do this with the OBD2 setup? If yes....check your grounds on the engine. IF no, check the harness....probably a loose wire in there.
Jason
FeRReTTi
Jun 16, 2015 03:53 AM
vtec-adykt
Apr 14, 2007 10:42 PM
vtec-adykt
Apr 11, 2007 06:24 PM
B18 CYA
Jun 1, 2004 11:22 AM
SI_Ro
May 18, 2004 08:19 AM
