problem with idling, after installing in JDM ls engine
Old Nov 25, 2004 | 03:02 PM
itsJDMyo's Avatar
Default problem with idling, after installing in JDM ls engine
my friend has a 91' integra RS, and we just swapped in a 95' JDM ls motor. and when we started it up, it just revved up to 4.5k and either stay there or keep going up. we adjusted the throttle cable and there isn't anything wrong with that. we also tried adjusting the TB, and it's not helping either. my friend said it could be the map sensor (which is bolted on the firewall) but how could i adjust it? or does anyone else know what the problem could be? and there is no check engine light either. PLEASE HELP, TRYING TO GET THIS DONE BY TONIGHT
Old Nov 25, 2004 | 04:15 PM
itsJDMyo's Avatar
Default Re: problem with idling, after installing in JDM ls engine (itsJDMyo)
Old Nov 25, 2004 | 04:22 PM
sykotic's Avatar
well, if it surges up and down at all it can be any type of vaccum leak? Do you hear a vaccum leak? Check all your vaccum hoses, check the seal around the injectors(the bottom seal)... if you can't find a leak and its not your idle screw or your throttle cable then try spraying starter fluid(carberatour cleaner?) around on hoses around the intake manifold, if it stops surging when you spray somewhere look for a vaccum leak on that hose... mmm i really dont know what else it could be.
Old Dec 1, 2004 | 06:15 AM
jeff 16's Avatar
You need to check the fast idle control valve on bottom of the throttle body. Or you can put the throttle body from you 91 rs motor to see if it goes away.
Old Dec 1, 2004 | 08:41 AM
stareatsun's Avatar
drive the car. seriously. i have read about a few people who have a fast idle problem and then drive the car. bring it up to highway speeds for a half hour and then shut the car off. the ecu needs to releard the motor after power has been lost to it sometimes. try it.
Old Dec 1, 2004 | 09:40 AM
sPaRk'iT's Avatar
Also check for bad TB and intake manifold gaskets, they could also be causing the problems.
Old Dec 1, 2004 | 09:43 AM
itsJDMyo's Avatar
Default Re: problem with idling, after installing in JDM ls engine (sPaRk'iT)
we found the problem, the new motor still had the old gasket on there, it was all torn up and ****...lol...stupid me
b20vteclsintegra
Oct 9, 2011 09:36 PM
Nomas04
Jun 19, 2009 07:46 AM
douboi
13
Oct 15, 2004 09:16 PM
vteckilla7
Aug 16, 2004 06:13 PM
CrXr89Si
Feb 23, 2004 08:26 AM
