Having a problem with my lsvtec
Old Oct 7, 2011 | 09:04 AM
b20vteclsintegra's Avatar
Default Having a problem with my lsvtec
So I have a lsvtec in my 95 integra. I have a check engine light thats one I did a check on the cells and one is #5 manifold absolute pressure sensor and #7 throttle position sensor. Also the car is in safe mode it does not want to go passed 3k so I dont not take it past it when driving. It does have a ls throttle body on it I have looked up so stuff and I also think that it has ls cable with ls bracket. So my quesion is if I change the throttle body and cable/w bracket to gsr and reset the ecu will the problem go away? Please let me know anything
Thanks
Old Oct 7, 2011 | 09:51 AM
kyden's Avatar
Default Re: Having a problem with my lsvtec
do you have the the plugs mixed up?
Old Oct 7, 2011 | 10:39 AM
I checked that and no the are good
Old Oct 7, 2011 | 02:59 PM
TTT anyone??
Old Oct 7, 2011 | 10:46 PM
mouab18c1's Avatar
Fix your map and tps sensor.
Old Oct 9, 2011 | 08:54 AM
ddwelch's Avatar
Make sure the pigtails for the map and tps arent switched.
Old Oct 9, 2011 | 09:36 PM
I did they are not cause I did switch them and the car would almost die put them back and it runs ok
b20vteclsintegra
Oct 27, 2011 11:33 AM
Nisif
Feb 12, 2007 08:35 PM
dc2integtypR
Oct 5, 2005 11:02 PM
SpoonEk253
Sep 26, 2005 12:03 PM
pmachan
Sep 7, 2005 08:18 PM
