Power windows
Old Jan 29, 2002 | 08:34 AM
ChaseIntegra's Avatar
Default Power windows
Is anyone having problems with their power windows rolling down? When I bought my car the [assenger side window wouldn't roll down. So my brother put some kind of lube on it and it worked for about 2 months. Now it won't roll down again. I know the motor isn't bad. What kind of lube do you recommend if anyone has had this problem?
Old Jan 29, 2002 | 08:48 AM
fiebru1119's Avatar
Default Re: Power windows (ChaseIntegra)
i've heard this happens alot on teg's, it hasnt happened to me so i wouldnt know what lube to use
Old Jan 29, 2002 | 09:08 AM
96IntegraLS4DR's Avatar
I use white lithium grease.
Don't use WD-40. it might destroy rubber parts in there.
Old Jan 29, 2002 | 09:24 AM
Pineapple Devil's Avatar
Default Re: Power windows (96IntegraLS4DR)
silicon spray. you can get it at autozone or places like that. just roll the window down and spray it on the side tracks of the window.
ThePunk's Avatar
As mentioned above, White lithium grease is the *Recommended* lube for this situation.
Best way to do it is with the spray style grease, not the brush on stuff.
Old Jan 29, 2002 | 09:43 AM
Headhunter76's Avatar
Default Re: Power windows (ThePunk)
I have a similiar problem. I had window automation installed with my Viper 300+ alarm. Everything worked fine until some motherless asswipe smashed my driver's side window and ganked $4000 worth of car audio. Acura replaced the window and it worked fine for two months. Now it stops like 4 times on the way down - either by using the remote (alarm) or the driver's side door switch.
I haven't pulled the door yet. Any ideas or similiar experiences?
[Modified by Headhunter76, 6:44 PM 1/29/2002]
Old Jan 29, 2002 | 10:03 AM
boosted1993fd's Avatar
http://www.accordclub.com/techtips/lube/
This has a accord pictured....but the same instructions go for Integras..and probably most hondas.
Old Jan 29, 2002 | 06:44 PM
Default Re: Power windows (Interlude)
Thank you all for the tips!
nateb22
May 6, 2009 12:09 PM
tekniq
33
Aug 3, 2008 09:26 PM
BlkEkCpe
Jul 10, 2005 07:56 PM
ericlee303
Jun 24, 2004 06:01 PM
