Power Window Problems
Old Sep 6, 2011 | 10:07 PM
DaiSeeFut's Avatar
Default Power Window Problems
hey i have a power window problem. So the driver side and passenger side windows sometimes decides to stop working on me. It will do that for minutes to hours to days, then start working again. i had the switches replaced with a used one three times (owners said they worked before and ive tried em before getting em) and they would work for a few weeks, and the problem would come up again. Rear windows all work. As of right now all four work, but the passenger side will sometimes stutter every so often. Im afraid to roll em down and have em stuck on the down position while i have to go to class. Any help? Thanks!
Old Sep 7, 2011 | 09:28 PM
DaiSeeFut's Avatar
Default Re: Power Window Problems
ttt
Old Sep 8, 2011 | 04:19 AM
DaiSeeFut's Avatar
no help?
Old Sep 8, 2011 | 07:17 AM
Dogginator's Avatar
Daisy... Daisy...
Check the plugs and the grounds. The problem with the passenger window could be the passenger side switch. What is this "stuttering"? Is the motor struggling?
Old Sep 8, 2011 | 12:49 PM
DaiSeeFut's Avatar
@Dogginator, i mean like if i hold it for a 10 second span, it will stop and go about 3 times before the window fully closes/opens.
Old Sep 8, 2011 | 04:29 PM
DaiSeeFut's Avatar
helpp!!!
Old Sep 8, 2011 | 04:52 PM
fcm's Avatar
fcm
Old Fart
Check your door jamb plugs, [where door harness plugs into dash harness at the "A" pillar.
Unplug them, spray terminals with WD40 or MoveIt and plug them back in.
I would also check the main power window fuse and the power window relay. 94
Old Sep 8, 2011 | 06:10 PM
DaiSeeFut's Avatar
thanks. will give it a try asap
Old Sep 8, 2011 | 06:29 PM
echoside's Avatar
x2 my passenger window randomly quit working for a while, a terminal right at the door jamb connector turned green and broke off, making an intermittent connection.
Old Sep 8, 2011 | 06:35 PM
DaiSeeFut's Avatar
thanks to you too
oldskoolDA6
May 2, 2008 05:45 AM
99hondacura
Feb 6, 2007 06:54 PM
jdizzel
Jun 26, 2004 06:29 PM
gtowni3
Jun 12, 2004 11:24 AM
Xerxes3333
Mar 10, 2004 06:56 PM
