is it possible to install ITR rear sway bar.. backwards??
I to Smooch Pickle
is it?? on my car. everything bolts.. it just.. seems funny, maybe just me
I to Smooch Pickle
Re: is it possible to install ITR rear sway bar.. backwards?? (Boges)
nah.. its impossible.. i just imagined it..
but just to make sure.. after the long bar that goes across the chassis, does the bar bend toward the lca, then loops over the lca right?? because that's how mine is.. and the endlink is never at 90 degrees.. but to be ok. o well
I to Smooch Pickle
Re: is it possible to install ITR rear sway bar.. backwards?? (thaiphob)
i gave it away to somebody already.. too late
https://honda-tech.com/zerothread?id=291990
.. like on those pictures.. does the bar seem to be bending towards the LCA, then goes over the LCA?? it does doesnt it?? because that's how mine is.. but the bracket is never at 90 degrees, maybe like 70 degrees or so.. seems ok though, but just want to make sure
Re: is it possible to install ITR rear sway bar.. backwards?? (mingchi69)
I beleive a few people have mistakenly installed the bar on backwards before. Everything should bolt up fine too.
Re: is it possible to install ITR rear sway bar.. backwards?? (Black-LS)
backwards.... umm... not unless they really tried...
... upside down... definite possibility. make sure the arms bend up and over the LCA's.
it is possible trust me. i have seen a picture before. here ill try to look for the picture.
edit. well i couldn't find one but trust me ive seen it before. ask bsq he is a member here.
Driven
03-27-2003 08:25 AM
