PLEASE HELP...OVERHEATING!!!!!!
Old Apr 15, 2006 | 11:49 AM
NosCivic01's Avatar
Default PLEASE HELP...OVERHEATING!!!!!!
search is unavailable so i need some answers now.
just got my motor back from the machine shop n installed it. it was built for turbo with pistons n ect. i have a cometic headgasket also.
now i start the car n it overheats when i drive. i blead the bleeder by the upper rad. hose and at first alot of air came out n then wen coolant finaly came out i closed it n topped off the radiator. then i drove it n it overheated again. wat is going on? im pretty sure the thermostat is opening but wat else could b going on?
Old Apr 15, 2006 | 12:18 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: PLEASE HELP...OVERHEATING!!!!!! (NosCivic01)
Are you losing coolant?
Perhaps when you/they put the coolant in, they didn't bleed it properly. When you do an engine overhaul, you gotta bleed it for a while since the block is basically empty.
Old Apr 15, 2006 | 12:23 PM
AspectIndustries's Avatar
Fan not turning on?
Trying turning on the HEATER on FULL FAN SPEED! while you leave the cap open. It may help get coolant circulate in there also. And just wait till all air bubbles come out.
Check for head gasket leaks.
xxitoonzxx
Feb 17, 2013 07:41 PM
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
96Integ
Mar 29, 2009 06:11 PM
vinuneuro
Jun 22, 2005 10:16 PM
bitr364
Jul 22, 2003 02:03 PM
