please help coilover install problems
Old May 10, 2003 | 02:02 PM
dre000's Avatar
Default please help coilover install problems
I am installing tein basics on my car, I just finished the front but when I lowered it down the top of the strut came way up out of the engine bay (i think i may have broke the stock mount) I cant figure out why this happened. thanks in advance for any help
Old May 10, 2003 | 02:29 PM
dre000's Avatar
Default Re: please help coilover install problems (dre000)
bump, please help this is scaring me pretty bad...
Old May 10, 2003 | 02:44 PM
P1mpSlap's Avatar
Did you unbolt ant of the upper control arm?
Rebolt the damper correctly?
Old May 10, 2003 | 02:47 PM
dre000's Avatar
Default Re: (P1mpSlap)
I just followed the instructions here
http://www.c-speedracing.com/h...r.php
Its like the whole coilover assembly is too short or something. I wish I could take pictures. I cant figure out what is wrong. I thought I did everything right.
Old May 10, 2003 | 02:56 PM
BlackB18CTeg's Avatar
Default Re: (dre000)
well i had somewhat the same problem...... Did a single bar just come up out the strut? If so It is because the washer isnt holding the bump stop so nothing stops it.
Old May 10, 2003 | 02:58 PM
dre000's Avatar
Default Re: (BlackB18CTeg)
yeah, the single middle bar where the top nut goes on. which washer is it? and how did you fix the problem? Im wondering if I may be missing something
Old May 10, 2003 | 03:08 PM
VTECorona's Avatar
Were the struts already assembled or did you have to DIY? I had the same problem and it was because I forgot to put this washer onto the shock shaft to make it stop when it hits the underside of the top mount.
PM me if u want, it sounds like the same exact problem I had
Old May 10, 2003 | 03:11 PM
Default Re: (97RedTegGSR)
its not the tube, its the washer under the tube.....
Old May 10, 2003 | 03:12 PM
VTECorona's Avatar
Yeah I know, I edited as soon as I realized I said tube
I drew a little pic in paint for you to show you what I'm talking about, PM me
Old May 10, 2003 | 03:17 PM
just be glad that your hood wasnt closed Im glad mine wasnt..
Old May 10, 2003 | 03:20 PM
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">just be glad that your hood wasnt closed Im glad mine wasnt..</TD></TR></TABLE>
That's EXACTLY what I said after it happened to me.
Old May 10, 2003 | 04:19 PM
dre000's Avatar
oh man I didnt think about that, good thing I lowered it with the hood open that would have been bad... haha
Old May 10, 2003 | 04:24 PM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre000 &raquo;</TD></TR><TR><TD CLASS="quote">oh man I didnt think about that, good thing I lowered it with the hood open that would have been bad... haha</TD></TR></TABLE>
lucky duck
Old May 10, 2003 | 10:59 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (NeoGSR)
You forgot the bumpstop plate (washer) that goes directly above the bumpstop, it keeps the shock from coming up thru the upper mount as you described. It's #15 in this pic:
yaryar
Suspension & Brakes
11
Jan 2, 2009 02:37 AM
SurfKid3
Suspension & Brakes
Jan 21, 2006 11:28 AM
nurvcom..
Suspension & Brakes
Dec 3, 2005 10:24 PM
hondaenthusiast
Dec 20, 2003 07:27 PM
StyleTEG
Mar 6, 2002 02:01 PM
