PLEASE HELP!
Old Aug 29, 2013 | 05:26 AM
eYezs1ck's Avatar
Default PLEASE HELP!
96 integra LS
radiator cap holds pressure
radiator no leaks
coolant in coolant reservoir seems higher than normal
visually see a small pulse in the coolant reservoir
a lot pressure build up after removed the radiator cap overnight
i had to pour some coolant to the radiator from the reservoir
upper radiator hose very stiff when running
no signs of and substance in spark plugs
no signs of substance coming out of tailpipe aka white smoke
no signs of milky substance in oil in dipstick
no signs of milky substance in the oil cap
idles at 1.5k
car overheats in idle
car in normal temp. while driving
fan works fine
what does it sound like?
Old Aug 29, 2013 | 03:24 PM
SolScifen's Avatar
Default Re: PLEASE HELP!
Have you tried bleeding the system?
92blm92
31
Nov 7, 2017 03:48 PM
Soooogie
Sep 29, 2013 04:54 AM
89sparks
May 14, 2008 07:38 AM
iwouldHITit
Jul 31, 2003 05:44 PM
spoolinlude
May 7, 2003 06:49 PM
