please help!!
Old Oct 19, 2009 | 09:07 PM
consumer's Avatar
Default please help!!
1) ROUGH idle like 800 to 600 over and over non stop...up,down,up,down...
2) accelration is awfull, stutters terribly... spits and sputters
3) will not go into 3rd gear... one in every 100 trys... it will go in perfect..
4) front/driver tire tread is wearing in some weird wavey surface..
5) massive wheel/road noise... not bearings, there is no play in bearing when car is jacked up and inspecting bearings...
6) short in light switch... sometimes lights dont come on unless you mess with the switch just the right way...then the lights pop on.
7) crappy gas mileage.
help... this is my DD
Old Oct 19, 2009 | 09:32 PM
ILS_09's Avatar
Default Re: please help!!
The rough idle could be many things from a bad distributor to a bad ecu. But you should consider cleaning your iacv and adjusting the idle screw. My guess would be a vacuum leak somewhere.Bad acceleration could be caused by many factors. I would consider checking the timming first, then for a clog cat, distributor, spark plug wires and spark plugs and work my way from there. Your car not going into third gear could be because you have no transmission fluid or clutch/brake fluid. It could also mean your clutch master cylinder is going bad. If worst comes to worst, then your heading to a new tranny because of bad syncros. The tired tread wearing could be because you are suffering from some type of chamber wear or needs alignment or new axles. Crappy gas mileage could be mainly from a bad/faulty o2 or clogged cat or fuel injector. Timming also plays a huge role in this. This is all I can help with.
Old Oct 19, 2009 | 10:28 PM
consumer's Avatar
thanx i really need to get this thing running better... my bmw is out of the game for a minute...and all i got is my teg.... thanx much.
Old Oct 20, 2009 | 07:37 AM
nsxtasy's Avatar
H-T Order of Merit
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old Oct 20, 2009 | 07:59 AM
consumer's Avatar
big help, thanx...although i think its a little late.. the post is already published... with a whopping one comment.
Old Oct 20, 2009 | 12:30 PM
consumer's Avatar
i need some help...ideas?
Old Oct 20, 2009 | 12:47 PM
Simkin314's Avatar
I think ILS_09 hit most of the nails on the head. I'll just add a few things.
1) Check for vacuum leaks
2) Check PCV, Oxygen sensor, etc
3) Your synchros may be going out. Always rev the engine to the approximate RPM for rev-matching purposes.
4/5) Alignment may be off causing uneven wear which would also cause bad road noise.
6) Replace light switch(?)
7) Back to O2 sensor, PCV
You have a lot of issues with your DD. Did they come all at once or something? #'s 4 and 5 may be linked as well as #'s 2 and 7.
Old Oct 20, 2009 | 01:01 PM
consumer's Avatar
no i traded the car for a 01 s10.. 450k miles... so i got the teg now.... and im putting my bmw on stands for a while...so the teg will HAVE to be the DD...
thanx for the info... need all i can get
KingLukeXVI
May 29, 2019 06:53 PM
hiimdavidchan
Jul 30, 2014 03:36 PM
dointhemzs
Sep 7, 2008 07:09 PM
LSV84
May 14, 2006 06:01 PM
dannyto
May 28, 2003 11:06 AM
