please Help
Old Feb 19, 2005 | 06:10 PM
ben_eg6's Avatar
Default please Help
hello, honda-tech members.
Please help me! this this car that I use for work and school.
Today my car died on me while I was driving home. first of all, the fuel pump didn't work. I checked all the fuses see if they got burn, but they were fine. I thought the fuel pump was bad so I took the whole gas tank out and checked it. the fuel pump worked fine when I conected straight to the battery but it didn't pump when I turn the ignition key on. then I tested the fuel pump plug see if there is any power, but no. Its a 91 4dr auto integra.
all of the fuses are fine, the fuel pump works, but the power doesn't reach to the fuel pump plug ( the plug thats located under the rear seat)
can some one please help me what I in order do to get the car run, or any links that show how to do it.
thank you very much for your input.
Old Feb 19, 2005 | 07:16 PM
virusiidx's Avatar
did you just say you pulled the whole gas tank out??
anyways, sounds like a short somewhere, check all the electrical lines. You should also try installing another fuel pump to see if that works or not, just to narrow it down.
Old Feb 19, 2005 | 09:49 PM
ben_eg6's Avatar
Default Re: (virusiidx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">did you just say you pulled the whole gas tank out??
anyways, sounds like a short somewhere, check all the electrical lines. You should also try installing another fuel pump to see if that works or not, just to narrow it down.</TD></TR></TABLE>
first of all, thanks for your input
to answer the question,
yeah, I did take out the whole gas tank out in order to get to the fuel pump because its a 91 Integra, the old model and its was a pain in the *** to do that
It must be the electrical lines some where but I dont know where to start. Could it be the Fule Main Relay?
lets hear more from other people!
Bump
Old Feb 19, 2005 | 10:32 PM
ben_eg6's Avatar
Default Re: (Eg6B18C1)
up
Old Feb 19, 2005 | 11:29 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg6B18C1 &raquo;</TD></TR><TR><TD CLASS="quote"> It must be the electrical lines some where but I dont know where to start. Could it be the Fule Main Relay?
quite possibly. that did it for me.
Old Feb 19, 2005 | 11:34 PM
EF-EF's Avatar
it has to be the main relay....
Old Feb 20, 2005 | 01:44 AM
ben_eg6's Avatar
Default Re: (EF-EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-EF &raquo;</TD></TR><TR><TD CLASS="quote">it has to be the main relay....</TD></TR></TABLE>
that is what I though too cuz all the fuses are still good but the power doesn't reach to the fuel pump
you guys know how much does the main relay cost at Honda dealer?
to the top................
Old Feb 20, 2005 | 03:05 PM
LSvtec03's Avatar
probably around 70 bucks from the dealer. why go there? try to find one elsewhere and save some money.
Old Feb 20, 2005 | 03:08 PM
Carnage R1's Avatar
gas tank out damn. bump!
Old Feb 20, 2005 | 10:43 PM
ben_eg6's Avatar
Default Re: (LSvtec03)
I got the main relay replaced today and got the car run, now I'm very happy
but one more problem that I have been having for along time is that the car idles like crazy.
when the car is cold, I have to keep my foot on the gas pedal the whole time, otherwise its gona died. it will get a lil better when its warm, but I also have to keep my foot on the gas dedal again when I stop at the lights or stop signs after a while of driving or it will died on me.
at first, I thought It would be better after I changed the fuel filter, so I dit that but nothing happened. after that, I tried to change the Control Idle which is located behind the Intake manifold to fix the problem, but its still there.
Now I dont know what I should do. Can someone please tell me what i have to do next to fix the problem cuz i dont know what else I should do.
I really appreciated your help. thanks
carracr625
Apr 19, 2019 06:29 AM
lmananT
Jun 4, 2008 10:56 PM
fwalcom
18
Mar 21, 2007 10:09 AM
arospeedintegra
Mar 6, 2007 02:26 PM
dyases
Apr 30, 2004 06:45 PM
