plastic fitting next to pcv?
whatever it is i just broke it:
anybody got a part #/ source?
looks like coolant runs through it?
i'd rather replace it if possible,
too inaccessible to rely on jb weld.
gotta replace the head gasket after almost 320k miles.
getting that intake off was a beyotch,
had to grind down a small socket wrench to get at those lower
middle intake nuts. :barf:
95 gs-r btw.
95 gs-r btw.
see the broken plastic stem sticking out of the black hose?
it was attached to the fitting next to the pcv.
i'm assuming i can pry the rest out?
if it's just for ventilation i might go with jb weld.
2 11853-PR3-000 GROMMET, BREATHER CHAMBER 002 1995 INTEGRA 2.97 2.23 Qty:
3 11854-PR3-000 JOINT, BREATHER CHAMBER 002 1995 INTEGRA 3.27 2.45 Qty:
http://www.acuraautomotiveparts.org/...s=&view=normal
My 95 LS has the pcv valve going into the intake manifold, and the rubber piece that goes in between the valve and the intake broke off. I pushed the valve directly into the intake and it seems to hold, but do you think it is affected (vacuum leak) or possibly not a sealed fit ?
Nikoli
Oct 26, 2004 02:40 PM
