What to do with this hose?
Old Aug 24, 2003 | 10:05 PM
Rick's Avatar
Default What to do with this hose?
When I was changing my oil today I noticed that the previous owner had connected the hose that goes from the valve cover to the intake arm with electrical tape. I took off the electrical tape and saw that was the only thing connecting the two. I tried fitting the hose over the fitment on the intake arm but the hose diameter is too small, so I just put some duct tape on it to hold it and refastened the clamp. I'll probably end up getting an intake for the car anyway, but how am I supposed to connect it otherwise?
Old Aug 24, 2003 | 10:24 PM
thaiphob's Avatar
Nikon!!!
Default Re: What to do with this hose? (Rick)
you could alway get a new intake arm. if your going to get a aftermarket intake then you shouldnt have any worries.
Old Aug 24, 2003 | 10:25 PM
B16OnTop's Avatar
just leave it, its prob got a good enough seal
Old Aug 25, 2003 | 12:06 AM
Loccster's Avatar
Default Re: What to do with this hose? (B16OnTop)
get a bigger hose from kragen
Old Aug 25, 2003 | 06:18 AM
BolivianDc2's Avatar
Default Re: What to do with this hose? (BlazinTeg)
i have to do something like that w/ the skunk 2 intke manifold install i did. The stock metal tube that goes in there is rippin out the plastic from the intake arm, that seems like a good idea to fix the prob.
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Um, there is supposed to be a metal tube that is actually 2 tubes welded together. One is for the valve cover breather, and the other is for coolant. I hope you have something in place to carry the coolant normally carried by the metal tube.
Old Aug 25, 2003 | 06:54 AM
ebelp's Avatar
Default Re: What to do with this hose? (thaiphob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">you could alway get a new intake arm.</TD></TR></TABLE>
I think just getting a larger diameter silicon hose would be a lot easier.
Old Aug 25, 2003 | 08:03 AM
IN VTEC's Avatar
Go to Lowes or Home Depot and get something like a ~5/16" barbed union fitting (barbed ends on both sides) to join the two. Try a few different sizes. Hose clamp them down to seal properly.
Or, if you want, I think we've got a spare stock metal thingy laying around that you can pretty much have. It'll require a little bit of thoughtfulness on your part to either separate the PCV tube from the coolant tube or find a way to arrange it so it doesn't damage anything if you don't want to reroute the coolant lines as they are right now.
Old Aug 25, 2003 | 08:10 AM
Seedc2's Avatar
Default Re: What to do with this hose? (IN VTEC)
I just did that over the weekend.. I went to home depot and purchased a metal barb double male sided 3/8" and it fit perfectly. only cost like 1.70~ (in plumbing section)
Old Aug 25, 2003 | 09:22 AM
junglistgsr's Avatar
Default Re: What to do with this hose? (kendogg)
looks like someone used to have an intake on their car.
Old Aug 25, 2003 | 12:22 PM
Rick's Avatar
Default Re: What to do with this hose? (junglistgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglistgsr &raquo;</TD></TR><TR><TD CLASS="quote">looks like someone used to have an intake on their car.</TD></TR></TABLE>
That's what I figure.
Old Aug 25, 2003 | 12:24 PM
Rick's Avatar
Default Re: What to do with this hose? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Um, there is supposed to be a metal tube that is actually 2 tubes welded together. One is for the valve cover breather, and the other is for coolant. I hope you have something in place to carry the coolant normally carried by the metal tube.</TD></TR></TABLE>
I thought this hose was for excess oil from the valve cover.
Old Aug 25, 2003 | 12:26 PM
Rick's Avatar
Can someone post a pic of what it is supposed to look like stock?
Old Aug 25, 2003 | 10:45 PM
Rick's Avatar
Default Re: (Rick)
anyone?
Old Aug 26, 2003 | 09:17 AM
Rick's Avatar
up
Old Aug 26, 2003 | 09:28 AM
stevieteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick &raquo;</TD></TR><TR><TD CLASS="quote">
I thought this hose was for excess oil from the valve cover.</TD></TR></TABLE>
It is a breather valve for the valve cover, to take in air. the reason that it is attached to the intake tube is so it takes in fresh, flitered air. I fit were an oil overflow it would be puoring oil into your intake tube and into your throttle body. You need to modify these things when you use a cai. I believe that you are suppost to link the two coolant lines together, or find a two metal hoses that can from the factory. Sorry I do not have a picture of it.
Old Aug 26, 2003 | 09:38 AM
Rick's Avatar
Default Re: What to do with this hose? (stevieteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevieteg &raquo;</TD></TR><TR><TD CLASS="quote">
It is a breather valve for the valve cover, to take in air. the reason that it is attached to the intake tube is so it takes in fresh, flitered air. I fit were an oil overflow it would be puoring oil into your intake tube and into your throttle body. You need to modify these things when you use a cai. I believe that you are suppost to link the two coolant lines together, or find a two metal hoses that can from the factory. Sorry I do not have a picture of it.</TD></TR></TABLE>
So it is hooked up wrong then? Rather then going out and snapping another pic here is a pic of which hose I have connected. The top left one is the one I have duct taped to the intake arm.
Old Aug 26, 2003 | 10:54 PM
Rick's Avatar
up.. anyone have a pic of how this hose connects?
giantgreenhead
Dec 9, 2007 02:24 PM
mugenspoongsr
Jul 1, 2005 08:35 PM
Rick
Aug 25, 2003 10:46 PM
AMG
Jun 6, 2003 07:55 AM
TeamTooQuick
Mar 30, 2002 06:07 PM
