P30 Pistons in LSVTEC Motor
Old Oct 11, 2002 | 08:06 AM
smnowell's Avatar
Default P30 Pistons in LSVTEC Motor
Hey, quick question. I was wondering if you can use the JDM P30 (B16A SiR2) Pistons in an LSVTEC motor. I know you can use PCT(CTR) or P73(ITR) in the LSVTEC...anyone with this knowledge, please help me out.
Old Oct 11, 2002 | 08:41 AM
martini's Avatar
Default Re: P30 Pistons in LSVTEC Motor (b16a ferio)
Sure, they are the same bore, and the valve reliefs will be ok. The rods should fit, but some minor machine work may be needed.
Old Oct 11, 2002 | 10:47 AM
WAFFLES's Avatar
Default Re: P30 Pistons in LSVTEC Motor (martini)
p30 pistons will go in no problem. just have them pressed onto your ls rods. good choice of piston too for lsvtec. about 11.2:1 compression.
The Type R pistons will work too, but the rod ends where the piston sets will need to be shaved 1mm on both sides.
Old Oct 11, 2002 | 12:47 PM
RenoRacing's Avatar
Default Re: P30 Pistons in LSVTEC Motor (WAFFLES)
how about just pr3(b16a) pistons into a ls/vtec(b18b w/ pr3 b18a head). What is the compression ratio of that. I use the stock ls rods right, just have them pressed as well? thanks guys
Old Oct 11, 2002 | 01:01 PM
JCushing's Avatar
Default Re: P30 Pistons in LSVTEC Motor (HavokRacing)
http://www.c-speedracing.com/howto/c.../compcalc.html
Old Oct 11, 2002 | 01:10 PM
rotten's Avatar
The P30, PR3, etc. pistons will work, but you'll need to machine the rods slightly as they are just slightly too wide. Nothing major.
215HPLSVTEC
Feb 7, 2014 07:30 PM
jhammond_82
Jul 15, 2009 04:44 PM
97accord_R
Mar 23, 2009 02:29 PM
hondadriver
Sep 30, 2006 02:58 AM
brnzbuddha
Sep 13, 2004 03:32 PM
