Performance LS Distributor....?
Old May 23, 2005 | 07:30 PM
Steak84SS's Avatar
Default Performance LS Distributor....?
Who makes a higher performance distributor for the 94LS? It doesn't look as is Moroso makes one.
Old May 23, 2005 | 07:39 PM
adseguy's Avatar
Default Re: Performance LS Distributor....? (skylinedo)
MSD, but that's if your pushin 400HP...otherwise your wasting your money stick with OEM
Old May 23, 2005 | 07:42 PM
Steak84SS's Avatar
Default Re: Performance LS Distributor....? (adseguy)
That's kinda what I figured. Just though I'd check. Anyone ever use an MSD Ignition box? I have one kickin around from an old project and never used it.
Old May 23, 2005 | 07:50 PM
sickofitall1113's Avatar
Default Re: Performance LS Distributor....? (Steak84SS)
if you want the best ignition go with crane, they make the top of the line ignition system
Old May 24, 2005 | 05:09 AM
Steak84SS's Avatar
Default Re: Performance LS Distributor....? (sickofitall1113)
Sure thing. I'll just buy a new one and forget about the one I already have. Besides, MSD is fine. You see more of those then Crane anyways.
Old May 24, 2005 | 06:37 AM
so put that one in and see how it is then. i was just saying that crane is better. thats all.
Old May 24, 2005 | 01:00 PM
Steak84SS's Avatar
Well you have caught my curiosity as to WHY Crane is better?
Old May 24, 2005 | 02:40 PM
worditsmenick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinedo &raquo;</TD></TR><TR><TD CLASS="quote">honda makes one it's called GSR OEM Distributor Cap
edit:
i dunno, try MSD ?</TD></TR></TABLE>
could you use a GSR distributor on a LS? i didnt think you could.
Old Jun 10, 2005 | 11:37 PM
Vera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steak84SS &raquo;</TD></TR><TR><TD CLASS="quote">Well you have caught my curiosity as to WHY Crane is better? </TD></TR></TABLE>
Crane Cams' ignition has a fully digital design (A Crane 1st since 1995!) For accuracy and absolute reliability! Robotic, surface-mount assembly, same as used in cellular telephones.
MSD's ignition has low-tech, analog design with hand-soldered, “spaghetti” wires that can break away and cause ignition failure!
Mikeflg
Engine Management and Tuning
Jan 10, 2012 06:01 PM
boostd ls
Mar 6, 2008 01:37 PM
Moe_Mentum
Sep 9, 2006 07:29 AM
seen4ever
Jun 20, 2005 05:56 PM
dyg2001
Feb 24, 2004 09:38 AM
