Overheating.. Help
Old Nov 11, 2005 | 09:06 AM
integraloco's Avatar
Default Overheating.. Help
i was wondering if anyone had a problem simular to mine.. when driving normally my temperature keeps climbing untill it overheats.. i checked my fans and wired my radiator fan to a switch so it stays on.. but even with the radiator fan on it still is rising to where it was before to start overheating. ive also checked my coolant levels and have filled them back up after everytime it overheats.. anyone have any ideas?
Old Nov 11, 2005 | 09:41 AM
Greddy Dantegra's Avatar
Default Re: Overheating.. Help (integraloco)
u got a leak somewhere... but if u wanna save money and not let your car overheat.... drive your car with fullblast of heat and your car would never overheat!!!!
Old Nov 11, 2005 | 10:36 AM
temp's Avatar
Default Re: Overheating.. Help (dvs gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvs gsr &raquo;</TD></TR><TR><TD CLASS="quote">u got a leak somewhere... but if u wanna save money and not let your car overheat.... drive your car with fullblast of heat and your car would never overheat!!!!</TD></TR></TABLE>
you are an idiot, please stop posting
**** man it could be a lot of things
bad thermostat, bad water pump, leaking water pump seal, leak somewheres, bad radiator cap, etc
Old Nov 11, 2005 | 11:35 AM
mlsmith95gsr's Avatar
You need to fix that leak because it's letting air into your coolant system. Be sure to remove all the air out of it everytime you refill your coolant. Let the car idle with the radiator cap off and there's also a valve you can open to remove the air.
Old Nov 11, 2005 | 11:44 AM
temp's Avatar
Default Re: (mlsmith95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mlsmith95gsr &raquo;</TD></TR><TR><TD CLASS="quote">You need to fix that leak because it's letting air into your coolant system. Be sure to remove all the air out of it everytime you refill your coolant. Let the car idle with the radiator cap off and there's also a valve you can open to remove the air.</TD></TR></TABLE>
not on all motors the 92-93 GSR i know for a fact has no bleed screw for the coolant, also just because air is in the system would not cause him to have to refill all the time, there is something else amiss here
Old Nov 13, 2005 | 09:08 AM
ex_crxer's Avatar
It appears that the rad is simply not doing its cooling job at all, the fluid is leaking of not making a full cycle. Check for leaks under the car after it overheats. If you can't see any leaking or if the fluid levels are OK you may want to check the entry point to your engine (thermostat) or the output point (Water Pump).
1995 Integra
Old Nov 13, 2005 | 09:18 AM
boucivicsir's Avatar
Default Re: Overheating.. Help (ex_crxer)
ive got a 99 si and my car is doing the same thing but the needle is only climbing a few mm. im guessing its the thermostat and the old fluid. i've got an appointment on monday at the dealer. ill try to let you know after...
Old Nov 13, 2005 | 10:37 AM
GoCarInteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex_crxer &raquo;</TD></TR><TR><TD CLASS="quote">It appears that the rad is simply not doing its cooling job at all, the fluid is leaking of not making a full cycle. Check for leaks under the car after it overheats. If you can't see any leaking or if the fluid levels are OK you may want to check the entry point to your engine (thermostat) or the output point (Water Pump).
1995 Integra
Old Nov 13, 2005 | 10:44 AM
92integraVTECgsr's Avatar
Default Re: Overheating.. Help (GoCarInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">not on all motors the 92-93 GSR i know for a fact has no bleed screw for the coolant, also just because air is in the system would not cause him to have to refill all the time, there is something else amiss here</TD></TR></TABLE>
You know for a fact?? Do you own a 92-93 GSR w/ the B17?
Cause I do, and I know for a fact that there is a bleed screw on the back of the block above the thermostat housing.
-----&gt; to the original question, you're leaking, thermostat is not working, or you're headgasket needs to be replaced. Check for leaks, maybe have a leakdown test done. Do you have a helms manual? you could go use that to try and diagnois the problem.
Old Nov 14, 2005 | 08:55 AM
temp's Avatar
Default Re: Overheating.. Help (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">
-----&gt; to the original question, you're leaking, thermostat is not working, or you're headgasket needs to be replaced. Check for leaks, maybe have a leakdown test done. Do you have a helms manual? you could go use that to try and diagnois the problem. </TD></TR></TABLE>
yes i do, i HAD a db2, i sold it, there was no bleed screw, follow the upper hose and there is NOTHING
Nickg116
Mar 31, 2007 06:20 AM
twenty
Jul 21, 2005 04:32 PM
coupon
Jul 21, 2005 10:42 AM
twenty
Jul 21, 2005 08:36 AM
nek0
Jun 16, 2003 05:05 AM
