Overheating Problems
Old Sep 10, 2001 | 10:04 AM
quickLSt's Avatar
Default Overheating Problems
My car tends to slightly overheat at idle (temp gauge slowly passes halfway and farther) but as soon as I drive or turn the heat on the temp drops. What could be possible problems? Could I have a blown headgasket? I can drive the car for a while before it starts to overheat.
Also, I just started to notice a noise (sort of high-pitched) when I press the gas, but as soon as I let off the noise goes away. Any thought to what that might be?
[Modified by elements150, 7:06 PM 9/10/2001]
Old Sep 10, 2001 | 10:17 AM
HX_Guy's Avatar
Default Re: Overheating Problems (elements150)
Start with the easy, inexpensive things like changeing the thermostat and see if that helps.
Old Sep 10, 2001 | 01:20 PM
Bozotk's Avatar
New User
Default Re: Overheating Problems (HX_Guy)
check that, and also check to see that your fans are kicking on when they are supposed too. if not, then you may wanna check the fan switch. if your fans dont kick on, and your car starts to over heat, you're gonna blow either some hoses, or your radiator. also, do not drive it anywhere if it starts to get too hot- it will really damage your engine.
Old Sep 10, 2001 | 01:25 PM
HX_Guy's Avatar
Default Re: Overheating Problems (Bozotk)
Good idea on teh fan switch. When yoi notice teh car is overheating..pop teh hood and see if the fans are on.
Old Sep 10, 2001 | 05:01 PM
Prelussion's Avatar
Hondas and Acuras are notorious for having problems with the fan relays, check those in your front bumper
Old Sep 10, 2001 | 05:03 PM
Prelussion's Avatar
Default Re: Overheating Problems (elements1.8t)
maybe you need a larger intercooler or your intercooler's not functioning properly.
Old Sep 10, 2001 | 05:04 PM
Prelussion's Avatar
Spool up?
Old Sep 10, 2001 | 05:17 PM
Turbohatch's Avatar
New User
Default Re: Overheating Problems (Prelussion)
it isn't spooling, its a different noise. i know when my car spools
tyler's car
May 26, 2014 07:12 PM
Shade93
Apr 13, 2010 01:15 PM
CARflyGUY
Nov 30, 2006 08:57 PM
KB96VTEC
May 23, 2005 06:30 PM
4U2NV
Jun 14, 2004 11:46 AM
