Overheating problem...
Old Sep 5, 2009 | 02:04 PM
  #51
sixfourkiller's Avatar
Default Re: Overheating problem...
well those number sound about right.. and No if the head gasket was blown it shouldnt have those number it be pretty low if your head was blown.
Old Sep 5, 2009 | 02:08 PM
  #52
hmmm im not sure if u check this but u change out the top of your radiator cap. cause if that not holding pressure then your car can over heat as well.. i know its simple but that over look alot and for sure that can cause your car to over heat as well.
Old Sep 5, 2009 | 05:31 PM
  #53
mikeSONICGSR's Avatar
I am getting a rad cap tomorrow to see if that is the problem, if it is not then I will most likely change the head gasket.
Old Sep 6, 2009 | 03:28 AM
  #54
b18cKoupe's Avatar
take it and get it checked to see if the coolant system is holding pressure. Aside from the radiator cap, the plastic tanks and filler necks on honda radiators are pretty well known for cracking with age. Its cheap to have a mechanic pressurize it and see if it holds, definately do that before the head gasket.
Old Sep 10, 2009 | 04:27 PM
  #55
shawn_crx's Avatar
I would bleed the air again....
1. take the rad cap off
2. turn your control temp switch to hot
3. let engine idle for 15 mins.
4. close cap.
make sure the front of the car is park incline a little higher then the back.
Also check for leaks at the reservoir, it may be crack at the top, and it will suck in air instead of water.
Old Sep 10, 2009 | 05:50 PM
  #56
4. close cap.
I will do that next, I filled up the radiator twice in the beginning of the week, cause I will still overheating, it has been 3 days now and I havent had to add any more coolant yet, and no overheating since.
Old Sep 10, 2009 | 11:14 PM
  #57
killaTeg's Avatar
i'm having literally the exact same problem, i replaced both of the temp switches and my thermostat and nothing has come from it. it will drive fine on trips just like yours, except my exhaust makes a pop sound sometimes while im driving and the engine like bogs down for a sec every once in awhile. Im gettin it pressure tested tomorrow cuz they think its the headgasket. not looking forward to that
Old Sep 11, 2009 | 06:11 AM
  #58
I am pretty sure it is my headgasket as well, I was trying to avoid it at all costs but I don't think I have any other choices. I am still going to do the hydrocarbon test to see if there is any oil in my coolant first.
Old Sep 11, 2009 | 11:43 AM
  #59
killaTeg's Avatar
got a call today apparently there is a coolant leak inside my engine, which means it could be a warped cylinder or maybe a crack in my block.
Old Sep 12, 2009 | 06:40 PM
  #60
jdmmik309's Avatar
well im havein the same promblem but a little diffrent check it. my car got a new head gaskit,and thermostat it dosnt over heat right a way but when i drive for a while it dose its a new block but it leaks out a lil at the hose witch is under the throttlebody. i dont get it at all. I been work on this car for a few weeks and spent more money then i have well its a( 94 civic 4 door with an b18a1) need helpppp
Old Sep 13, 2009 | 07:57 PM
  #61
ls_vtec_da's Avatar
your fan is not working
Old Sep 14, 2009 | 05:59 AM
  #62
I will be doing the head gasket this weekend, I will let you know the results.
Old Sep 14, 2009 | 09:43 AM
  #63
ls_vtec_da's Avatar
make sure since it overheated to resurface the head because it will be warped from being overheated.
Old Sep 19, 2009 | 06:09 AM
  #64
jdmmik309's Avatar
well thanx for the help im start a rebuild today
Old Oct 11, 2009 | 06:07 PM
  #65
eaglewesman's Avatar
Have you checked your ECT (Engine Coolant Temperature) sensor? How about the ECT Sending Guage? I'm not sure what you're driving but I have a 93 LS. Is the Fan Switch separate from these? It's hard for me to understand if people are saying "fan switch" when it's actually the ECT, or if "fan switch" is the real name...?
92_JDM
Engine Management and Tuning
Aug 16, 2010 02:40 PM
thakidd
May 15, 2008 01:45 PM
FOrSfEd
Feb 5, 2004 04:48 PM
jseames
Aug 22, 2003 12:38 PM
intekragsr
Feb 5, 2003 02:19 PM
